help car is not right
Old May 30, 2005 | 01:46 PM
GIsnickers's Avatar
MAF sensor connected ok? Vacuum connected from MBC to Turbo ok? Sounds very odd.
Old May 30, 2005 | 02:06 PM
Steven's Avatar
Originally Posted by scherejs
ok well i can't pull the code cuz it won't stay running. so i can't make it to autozone. i double checked the timing marks on the gears relative to the valve cover and it's still fine.
It doesn't have to be running to pull a code. Just roll the key to the start position and let the code reader scan. Have you done a boost leak test? Visual inspection only gets you so far. I'd be willing to bet something isn't right with the pump. Check the seal on the top of the pump and make sure it's seated properly. I had a customer who's 1G would drive under vac. then fall on its face under boost do to this.
Old May 30, 2005 | 02:07 PM
scherejs's Avatar
yea everything is connected. now at a very lopey idle if i give it a little gas and let off it starts idling at 2200 rpm. i also now notice what seems to be an odd tick or rattle that comes and goes. since the idle got better other than the rattle i tried to drive it, but as soon as i give it throttle under a load it cuts out.
Old May 30, 2005 | 02:10 PM
scherejs's Avatar
also what i previously asked. could this be symptoms of timing being off on balance shaft or the bottom sprocket on timing belt?
Old May 30, 2005 | 02:20 PM
Steven's Avatar
The balance shaft would cause lots of extra vibration but the car will still run fine. (the engine will shake a ton!) I'm 99.9% sure it has nothing to do with the bottom sprocket. Timing being off however, could cause symtoms like this. You can check it easily without pulling off all the covers. (only have to remove the top at the cam gears)
Old May 30, 2005 | 02:24 PM
Steven's Avatar
Sorry I misread the part about the sprocket, but yes it does sound possible that the timing could be off. I'd check it first, if it's right, I'd go back and check the pump.
Old May 30, 2005 | 02:30 PM
bigjhoney's Avatar
+1 many people take the balance shafts off all together when they redo the motor.
Old May 30, 2005 | 02:36 PM
Steven's Avatar
I remove them every time.
Old May 30, 2005 | 02:38 PM
7rider's Avatar
sounds like a problem with the install of your new fuel pump.
Old May 30, 2005 | 04:42 PM
scherejs's Avatar
ok i checked the bottom timing mark and it is 1.5 right of tdc. going by evomoto's install this is normal. so now i am totally stumped.
Old May 30, 2005 | 05:51 PM
Tim@AMSperformance's Avatar
CHECK THE CAM TIMING, make sure MAF is plugged in. I highly doubt a fuel pump would go bad that fast but it may have been installed improperly
Old May 30, 2005 | 07:57 PM
scherejs's Avatar
ok i broke everything down again and now i'm 100% sure everything is in time. i'm going to put the stock pump back in tomorrow to see what happens.
Old May 31, 2005 | 05:29 PM
scherejs's Avatar
well i figured it out, it was the fuel pump. thanx everyone for suggestions and help.
Old May 31, 2005 | 05:34 PM
rufus1's Avatar
fuel cut
dude it sounds like fuel cut. Get a flash that will fix it or A fuel cut defender.
Old May 31, 2005 | 07:34 PM
scherejs's Avatar
no the pump was shorting out. i put my stocker back in and it ran fine. i then put another walbro 255 in and it runs fine.
