racing valve question
Old May 30, 2005 | 08:10 AM
Derek888's Avatar
What exactly is a 3 or 5 angle valve job when building the head? What are its benefits and is it necessary?
Old May 30, 2005 | 08:14 AM
VTEC Killer's Avatar
its how many angles they port the valve openings. So in a 3 angle, they port it from 3 different angles, and a 5 angle, well, they port it from 5 angles. It is done to increase the flow of air into the cylinder and also make the air flow more smoothly. You can do a valve job and still stay with a stock sized valve, or you can go to a 1mm oversize valve, which again allows more airflow. On a stock size valve you can make up to 500whp easy.
Synter's Avatar
bump cuz im interested to know too.
Last edited by Synter; May 30, 2005 at 08:15 AM. Reason: anwser popped up b4 my post
Old May 30, 2005 | 08:26 AM
Derek888's Avatar
I already have the 1mm oversized racing valves... will 5 angle be better than 3?
Old May 30, 2005 | 09:03 AM
yes
Old May 30, 2005 | 09:14 AM
Deepseadiver's Avatar
How much for the oversize valves and valve job?
Old May 30, 2005 | 09:15 AM
Derek888's Avatar
you asking me?
Old May 31, 2005 | 04:36 AM
I was just curious.
Old May 31, 2005 | 05:29 AM
Derek888's Avatar
around 1200 including porting the intake- exhaust, cams, cam gears, 1mm oversized racing valves and 3 angle valve job
Old May 31, 2005 | 05:45 AM
eve-slow's Avatar
$1200 for all that? pretty cheap.
Old May 31, 2005 | 07:51 AM
Derek888's Avatar
yea... labor is cheaper in Taiwan
Old Jun 2, 2005 | 07:59 AM
eve-slow's Avatar
sweet!
Old Jun 2, 2005 | 09:20 AM
Derek888's Avatar
do you think I should port the intake manifold as well? Its costing me 80 bucks, what hp numbers can I get with it? I might as well do it to match the ported intake and exhaust head
Old Jun 3, 2005 | 06:06 AM
eve-slow's Avatar
80 bucks? Hell ya you should do it!
Old Jun 3, 2005 | 09:28 AM
cruizinmax's Avatar
You can think of multi angle valve jobs like routering a countertop. The more angles the smoother the radius on each side of where the valve and seat actually touch.
k20turbo
May 23, 2016 08:27 AM
3gevoclipse
Dec 30, 2015 11:46 PM
_des_
Sep 5, 2015 02:59 PM
GravityKnight
Jun 27, 2015 08:06 PM
yellowman
Jun 16, 2005 11:00 PM
