OBDII Pocket logger\code reader .......
Old Jun 1, 2005 | 09:39 AM
GOKOU's Avatar
Recently, the CEL light have been coming on and off at idle. I took it to autozone and the code was P0300. I'm tired of taking the car to autozone!
Is there a good OBDII pocket logger\code reader out there that can be use? Can a logger read and erase DTCs as well? Not sure if I should just spend the extra $$$ and get a logger or just get a code reader.
This car is too paranoiding!!!!
Thanks.
Old Jun 1, 2005 | 10:36 AM
Evo007's Avatar
Take a look at this site.
Pocket logger
Old Jun 1, 2005 | 10:38 AM
naucrx's Avatar
Hmm, that's Tuner Stein not Pocket Logger.
Here's the real deal Pocket Logger I'm using this, and it works great for clearing CEL's
Old Jun 1, 2005 | 11:00 AM
Evo007's Avatar
they have a palm app that loggs data.
Old Jun 1, 2005 | 12:12 PM
turbolarry's Avatar
Used tunerstein for a while and it clears codes fine.
Old Jun 1, 2005 | 01:29 PM
Ted B's Avatar
Here's what you do...
Go to Ebay and search for a "Creader" OBDII scanner.
Plug it in, leave it plugged in, and tuck it in the dash valence so it doesn't get in the way.
You'll never experience the PO300 or any misfire so long as you leave it plugged in.
Old Jun 1, 2005 | 01:48 PM
GOKOU's Avatar
Thanks. Sounds like a good band-aid. Do you know if this will prevent the ECU from logging other valid DTC?
Old Jun 1, 2005 | 01:56 PM
Ted B's Avatar
It will so long as it's plugged in.
Every rose has its thorn, but this one is small in comparison to the aggravation of dealing with PO300 related misfire.
Old Jun 1, 2005 | 04:55 PM
titaniumkingpin's Avatar
whats a good obdII cable and software for logging on a laptop?
anyone have reviews of any?
Old Jun 1, 2005 | 04:58 PM
EVO8LTW's Avatar
I've got the OBDII PocketLogger. No problems. Reads/clears CELs and logs the usual OBDII stuff (but doesn't log knock).
Old Jun 1, 2005 | 05:12 PM
djmikeymike's Avatar
i think i'm going to give this a try......scan tool and dynamometer in one....i just don't know if i want the palm or the PC version........
i would be really cool they would have inputs to log Wideband and EGT.....and i don't understand why they can't read/log Knock
