HKS2835 numbers
Old Jun 5, 2005 | 12:30 AM
mikiblueeyes's Avatar
HKS2835 numbers
Does any one have HKS GT 2835 kit??
I need to know what spool to expect comparing to stock turbo???
And also what Pump gus numers are realistic for that turbo?
Old Jun 5, 2005 | 07:04 AM
jj_008's Avatar
The turbo is rated at ~420hp at the crank. With the 71mm compressor wheel it will probably spool up realistically around ~400-600RPM over stock. Expect a 40-50hp gain on pump gas over the stock turbo. Maybe 40hp more on race gas.
Old Jun 5, 2005 | 08:43 AM
Drifto's Avatar
The stock turbo on pump gas makes more than 420 crank with the right mods.
Old Jun 5, 2005 | 09:12 AM
Thanks evry1.
Do you think its worthwile to go with 2835 or with 3071?
Which one would be less laggy and better for street?
Thanks
Old Jun 5, 2005 | 09:56 AM
rlazer5000's Avatar
I would think the 2835 would be less laggy, but the 3071 has a lot more HP potential.
Old Jun 5, 2005 | 11:21 AM
Mercenary3's Avatar
Persoanlly Id rather have the stock turbo than the GT2835. Its a nice little upgrade, but considering the cost, effort, time, and aggrivation associated with an aftermarket turbo for relatively minimal gains, whats the point?
AMS claims the 3071 is a great street turbo with decent potential and the 3076 is a comprimise between street and strip with more potential at higher boost levels.
Ive heard the 3071 will put down ~400whp on pump and the 3076 about 420-430. On race, the 3071 runs out quicker than the 3076. Also, the 3071 should spool up only a few hundred rpm later than stock, 3076 maybe 600-700 rpm later.
IMO if you want a really steetable turbo with some actual potential, 3071 is the choice...and if your willing to sacfice a little more lag for power, 3076. But i woulndt go smaller than 3071, considering the cost/gain potential.
Old Jun 5, 2005 | 11:36 AM
Cool. I was just looking to have fast spool (stocklike) more HP and Better response uptop as stock runs out after 6K-6500>
Old Jun 5, 2005 | 11:44 AM
Kevine326's Avatar
look at the slowboyracing.com sbr GT35r
quick spool up.. 3500 rpm range I believe with a high power output.
Old Jun 5, 2005 | 12:25 PM
Blitzbaster02's Avatar
gt28 is WEKSOS
Old Jun 5, 2005 | 04:14 PM
jj_008's Avatar
Originally Posted by mikiblueeyes
Thanks evry1.
Thanks
The GT2835 will be less laggy on the street then a GT3071, by a few hundred RPM. The GT2835 uses the same compressor wheel and A/R housing as a GT3071. The only difference is the smaller turbine wheel (54mm GT2835 and 55mm GT3071). A GT3071 is rated at ~450hp at the crank compared to the 420hp of the GT2835. The transient boost response will be better on the GT2835, but it gives up 30hp.
The problem w/ the HKS kit is the high price. Of course, most shops will slap on any turbo you want w/ their turbo kits.
Old Jun 5, 2005 | 05:43 PM
Thanks a lot jj008... Very informative.
Old Jun 5, 2005 | 05:52 PM
Hey one more question... Check this auction on ebay 7978970386 . Is it real to get 40WHP just by this bolt on. I have 330WHP now and would it take it to 370WHP by this mod. Sounds nice if its true.
Please feedback.
Thanks
Old Jun 5, 2005 | 06:25 PM
Evo007's Avatar
Good find, Anyone have any experience with this?
southpaw
23
Feb 24, 2021 12:24 PM
Seba
36
May 6, 2015 05:30 AM
dahuii77
20
May 20, 2010 01:21 PM
mlee25
15
Apr 21, 2010 07:59 PM
dahuii77
10
Oct 30, 2009 08:27 AM
