EVO VIII final drive ratio?
Old Jun 8, 2005 | 11:50 AM
  #31
Rob'Z's Avatar
Ring gear has 43 teeth, pinion has 13...
This results in a 3.307 ratio.
So this is the "rear end" ratio for the EVO VIII?
I may be able to use this for my project. A 3.15 from an E36 M3 or 3.23 from an M Roadster will suit me better but at least I have some options open.
Thanks everyone.
Old Jun 8, 2005 | 11:56 AM
  #32
dohcvtec's Avatar
Is this going to be a RWD evo or something? You'll need to consider the "front end" also.
Old Jun 9, 2005 | 12:57 PM
  #33
Rob'Z's Avatar
Not an EVO at all...
https://www.evolutionm.net/forums/sh...d.php?t=135077
http://www.hayabusa.org/cgi-bin/busa...24;t=25326;r=1
If I go with the Twin Busa setup (most likely) that is where the "rear end" will come into play. The '95 E36 M3 3.15:1 LSD looks like the best compromise between acceleration and top speed. Also, is the EVO rear diff an LSD? I need a limited slip for sure.
If I do go with the EVO VIII drivetrain it will all be in the transaxle. Either an RS 5-speed (LSD) and figure a way to eliminate the transfer case or a Lancer 5-speed (if it bolts up) with aftermarket LSD.
Old Jun 9, 2005 | 01:49 PM
  #34
Noize's Avatar
EvoM Administrator
I think our gearing is almost perfect.. Until you upshift to 5th gear. At that point, the car really lays down. There's a link that tells max gear speeds above, but the mph numbers on it aren't correct. The max gear speeds for a US Evo on 235/45/17s are as follows:
1st- 40mph@7000rpm
2nd- 60mph@7000rpm
3rd- 83mph@7000rpm
4th- 113mph@7000rpm
5th- 162mph@7000rpm
As you can see, there's a 50mph jump from 4th to 5th. Fortunately, even with light ECU mods, a stock internalled can see 7800rpm with no problems. 4th gear at 7800rpm is 126.5mph, which prevents most cars (unless they have major mods and quite a large turbo) from having to upshift to fifth in the quarter mile.
Old Jun 9, 2005 | 01:52 PM
  #35
DCSilvrEvo's Avatar
1st- 40mph@7000rpm
2nd- 60mph@7000rpm
3rd- 83mph@7000rpm
4th- 113mph@7000rpm
5th- 162mph@7000rpm
As you can see, there's a 50mph jump from 4th to fifth. Fortuantely, even with light ECU mods, a stock internalled can see 7800rpm. 4th gear at 7800rpm is 126.5mph. That prevents most cars (unless they have major mods and a large turbo) from having to upshift to fifth in the quarter mile.
IMO, above ~125mph, the stock gearing in the Evo gets pretty soft.
What about the MR Gears?
Old Jun 9, 2005 | 01:53 PM
  #36
jj_008's Avatar
Originally Posted by RS2
If I were you, I'd go with an RS gear ratio 3 ~ 5 and a custom F.Gear Ratio
Left = RS
Right = GSR
Gear Ratios
1 a 2.785 2.785
2 a 1.950 1.950
3 a 1.444 1.407
4 a 1.096 1.031
5 a 0.825 0.720
Rev 3.416 3.416
Final Gear 4.529 <---- replace this with 4.xx (lower than .529) or 3.xx
That is exactly what I am looking for. Thanks .
Old Jun 9, 2005 | 02:07 PM
  #37
Noize's Avatar
EvoM Administrator
MR _gear spacing_ is way better, because the fourth is a little shorter and the fifth is significantly shorter. I don't know about the longevity of the box, since an extra gear is occupying the same physical space, but I'd be more than willing to try an MR box if I were you.
The only thing that sucks about the 5 speed is the tall 5th, but that was done to preserve fuel economy at interstate speeds.
Old Jun 28, 2005 | 08:31 AM
  #38
_007's Avatar
What are the draw backs with the final gear by TRE if any. Is there anyone that has this?
Old Aug 3, 2005 | 12:50 AM
  #39
StabMasterArson's Avatar
Nice thread
I'm thinking about going with the HKS Kansai Service 5spd Final Drive Gear to help out my top speed for the Silver State Classic Challenge next year.
Old Aug 3, 2005 | 06:01 AM
  #40
Fourdoor's Avatar
Left = RS
Right = GSR
Gear Ratios
1 a 2.785 2.785
2 a 1.950 1.950
3 a 1.444 1.407
4 a 1.096 1.031
5 a 0.825 0.720
Rev 3.416 3.416
Can anyone confirm with some links that the US spec RS has different gear ratio's than the regular EVO VIII? Since I just purchased an RS I am wondering about this because speeds vs RPM are the same in 5th as they are in my 03 Evolution, so I suspect that the 5th gear ratio is identical.... not different like that list shows.
Thanks,
Keith
Old Aug 6, 2005 | 05:05 AM
  #41
RS2's Avatar
RS2
Unfotunately US-Spec Evo's don't come with the JDM 5th gear ratio 0.825
Try Norris-Designs he might be able to help with the 5th gear ratio "RS"
Thank goodness I have the 0.825, 1 other thing my custom FGR is here woot! 4months wait
Installation will be done by end of this month *hopefully*
Llew
21
Nov 19, 2025 06:38 PM
bracer
Feb 8, 2020 01:56 PM
honda-guy
13
Sep 18, 2018 08:50 PM
nudge120
Feb 23, 2011 08:01 AM
discopotato03
Jan 10, 2011 12:52 PM
