REMOTE STARTER: Keeps firing.
Old Jun 7, 2005 | 07:47 PM
CuniTEVo8's Avatar
Hey guys,
I have a remote starter on my car...recently, I've noticed that when I remote start....the car will keep firing for a lack of a better term. For instance, if you were to start your car up regularly with a key...but when you turn your key to start the car, and hold the key down after its been started...thats what the remote starter will do....does anyone have a clue as to why it's doing that?
It only happens sometimes, but its frequent enough ...like 2 outta 5 times..
Old Jun 12, 2005 | 09:06 AM
raiceboi697's Avatar
its probally screwing with the imoblizer (bad spelling i know) feature
Old Jun 12, 2005 | 09:28 AM
Cajun Power's Avatar
There are programming option that tell the remote starter to start for X time and it the car is not running to try again in X seconds. It may not be properly sensing that your car is running and trying to refire it. Get in your settings and turn off the restart option. See if that fixes it.
Old Jun 12, 2005 | 09:36 AM
LEVIII's Avatar
What brand is it?
If it is DEI (viper, clifford matrix) pm me and Ill tell you how to reprogram the tach to it and that should take care of it
Old Aug 1, 2005 | 01:22 PM
CuniTEVo8's Avatar
I dont mean that the car starts...and idles..and then the car tries to restart again..I mean like...only the first time it tries to start...
imaging that you are starting your car with a key...but you hold the key down even after its started....that's what happens....but since it is the summer..it hasn't done it since..only in the cold weather..weird.
Old Aug 1, 2005 | 01:49 PM
lookEVO's Avatar
hmm......thinking about doing that when I get mine installed, those ghey basturds said they wouldnt do it at best buy (got a good deal to buy it and free install) he tried to tell me it was illegal, i said yeah whatever. either way any one know of a how to on wiring the remote start up. I know it takes a spare key.
Old Aug 1, 2005 | 01:50 PM
lookEVO's Avatar
it might be resistance in the wiring......cold weather adds to it. dont sweat it too hard, unless you wanna double check all the slice and stuff.
Old Aug 1, 2005 | 01:58 PM
90GSX-03EVO's Avatar
It is illegal. In order for the remote start to work, you have to leave the car out of gear when parked, which is illegal in most states. However, that's not the point.
CuniTEVo8: The problem that you are encountering with the car continuing to crank the starter motor is because the alarm is not sensing that the motor is turning over fast enough to be "started" so it is continuing to try and start the car. The reason it is intermittent is because it is not properly "calibrated". Follow LEVIII's advice.
Old Aug 1, 2005 | 03:09 PM
lookEVO's Avatar
illegal to leave it out of gear.......that is extremely absurd........im sure its true but that is Fnckin ghey. I can do whatever I want to my car and no PIG (I like cops) can tell me what to do.
Old Aug 1, 2005 | 03:13 PM
titaniumkingpin's Avatar
i've never heard of anyone getting a ticket for leaving a car parked out of gear.
Old Aug 1, 2005 | 03:18 PM
QAT-R's Avatar
+1 but I know for damn sure that it is illegal. Anyway, can someone suggest a good kit? I hope its not too hard to wire.
