Question on MBC Low boost 1st,2nd,3rd gear
Guys,
Quick question. I have a perrin MBC and for some weird reason I do not get full boost in 1st, 2nd and 3rd gear. In forth and fifth I get spike to 22psi and then holds at 21, were it should be. In first is get like 18 and then holds to redline, In 2nd I get the same, In third I get maybe a hold at 19psi. Any thoughts? Thanks for any help.
Originally Posted by ct9a gsr
Generally, on the stock turbo, you'll boost higher in higher gears. I'd recommend adjusting your boost to where you want it to peak at in 4th gear.
that will happen in every car... you do not make enough load in lower gears to see the same numbers in higher load gears. this is good... because if you set your boost gauge in 2nd gear... you'd blow your engine in 4th and 5th
freshevo8
May 7, 2010 05:38 PM
Silv3r-eVo
15
May 16, 2008 06:53 PM
anjapower
May 9, 2005 01:07 PM
TonyG
Apr 10, 2004 07:24 PM
