How to run NITROUS
Old Jun 20, 2005 | 05:16 PM
PHILLY EVO's Avatar
Originally Posted by bigjhoney
sorry for invading the thread, but with the n-tercooler sprayer, do you need somekind of a tune for it , or is it just bolt up and use it whenever you want.
I dont know im trying to find out
Old Jun 20, 2005 | 05:18 PM
PHILLY EVO's Avatar
Originally Posted by rraulston
I just installed a NX 75 shot. Spraying in first makes me drive through the clutch. So i installed my arming switch on my shift lever with a piece of metal. Wish i had a picture. Anyways, when i shift into second, the switch hits the edge of the console and activates the system, foot to floor and it sprays. So i spray 2-4th gear at 90% throttle position and higher. My driving sucks, but i did a 12.4 at 118mph. Need to practice. RRR
hey can you post a pic of that on here
Old Jun 20, 2005 | 06:29 PM
Evol_VIII's Avatar
Any more information on your setup might be a big help. Are you spraying a 75shot pump gas and what type of boost are you running? I assume you are running a map just for the nitrous with the UTEC.
Old Jun 20, 2005 | 09:14 PM
sgplancer's Avatar
Joker stole my idea... well not really, but damn I mentioned it to him!
My theory was to utilize the 1st gear activation into a switch mounted on a piece of steel bracket. Since the shifter linkage (or cable system) is a linear non-typical system, and not prone to movement when engine/tranny is under load, you could in essence create a switch for each gear. This would be benificial for more than just a no2 system that doesn't spray in 1st gear. Think on more a global deal, like the utec. You could have a single map for each gear, but bypassing a few other things, would initially hinder its operatiion, but I am working on it.
Sorry for the comment!
Old Jun 20, 2005 | 10:18 PM
rraulston's Avatar
o.k. here are the pics. Its really basic, and it works FLAWLESS. Once you shift into second, the switch is activated and stays on throughout the run.....total cost......10 cents.... Ray
Attached Thumbnails How to run NITROUS-ray777.jpg   How to run NITROUS-ray888.jpg
Old Jun 20, 2005 | 10:47 PM
PHILLY EVO's Avatar
great set up thanks..
Old Jun 21, 2005 | 12:33 PM
DSMotorsport's Avatar
Proof that nitrous works great on an evo8:
https://www.evolutionm.net/forums/sh...ht=nitrous+dry
Pictures of the install
http://www.diamondstarmotorsport.com...sinstall.shtml
D Walk3r
Mar 4, 2015 10:29 AM
Dragking2189
22
Aug 25, 2011 04:36 PM
Spaggs
Lancer Engine Management / Tuning Forums
Jun 5, 2011 08:05 PM
EVOlunchbox
10
Feb 13, 2004 05:39 AM
