Break In Period question
Old Feb 21, 2003 | 10:29 AM
indica's Avatar
I need some advice from someone who owns an evo about how you went about breaking in your motor. Should i use synthetic oil? Should I really change the oil after the first 500 miles?
Should i use a rev limiter or do i want it to be driven over the whole range? how many miles? etc. break it down and dont be gentle.
Old Feb 22, 2003 | 09:07 AM
leonard_shelby's Avatar
I've always been a fan of varying the rpms / on the gas off the gas (but still staying far below 5K ) to fully expand / set the rings. Curious how I'm going to do that and not spool the turbo up even a little. Best I've found (whilst exp in my GSX) is very smoothly and slowly raise the rpms in say 2nd gear, this seems to produce a minimal amound of boost.
Other then keeping the revs below 2500 for the first 150 miles I agree with Claudius 100%
Old Feb 22, 2003 | 10:36 AM
chronohunter's Avatar
Originally posted by Claudius
Hi there
the first 400 - 500 miles, you shouldnt boost the car at all. Boost depends on gear and throttle position.
Keep revs below 2500 for the first 150 miles or so, below 3000 until you've done 300 miles, then progressively more. Change the oil at around 700 - 900 miles, then progressively increase rpms say up to 5000 and boost it. After you've done 2000 miles, I'd change the oil again and then blow fresh oil through the turbo.
NEVER boost or go over 3000 rpms when the car is cold, ie before you've driven 10 - 15 miles and the oil temp is around 85 - 90°C.
Leave the factory oil (whatever that is) in there for the first 700 miles, then change to fully synthetic 10W60 (I use Castrol RS).
I wonder after made us wait soooo DAMN long for the cars (and we're still waiting), how many of us will have the paitence remaining to follow the propper break-in
I'll need a throttle stop or something
Old Feb 22, 2003 | 11:07 AM
indica's Avatar
Thanks guys!
I read somewhere the factory fill is Mobil-1 Synthetic.
I agree it is going to be difficult not to let go, but I figure as long as I don't crash this car I will probably have it until I die, i can take it easy for a first couple thousand miles. when the odo hits 2001...
Old Feb 25, 2003 | 03:01 PM
Evo 8 fan's Avatar
The tires need about 200 to get "scrubbed", as was pointed out, keep below 5000 rpm's for about 500 miiles and take it easy on the brakes for about 300 miles. Your EVO will thank you. You will have lots of time to put it through its paces
evo_yoshi15
May 9, 2016 01:56 PM
5LEEPERISAH23I
10
Mar 16, 2014 10:17 PM
Frew
Aug 5, 2013 08:02 PM
ToMuchBoost
11
May 21, 2009 08:37 PM
lancergsrix
16
Dec 1, 2006 01:52 PM
