ARP Headbolts needs to be Re Torque, yes or no
Old Jun 24, 2005 | 05:32 AM
GOKOU's Avatar
Originally Posted by siantjab
I did mine to ~75 pounds on install. Then, after a few days, opened that valve cover back up and torqued them down to ~85 pounds. There was one that had backed out a tiny bit and was a little under torque (~68 pounds). I've since checked them again and all were fine.
Good luck!
Thanks. Looks like 85 is the magic number.
Another question. What is the torque cycle method?
replace first one and torque to 70 initially, then start with second one and torque to 70, etc. Then finally go back and retorque all to 85?
or
replace first one and torque to 70 initially, then torque that one to 85, then start with second one and torque to 70, to 85, etc.
Old Jun 24, 2005 | 06:00 AM
siantjab's Avatar
Use the first method, but torque to 75 pounds. *Allways torque these when the engine is COLD* After you've torqued them all to 75 put it all back together. Run the car normally for a day or two. Then go back in (again while the engine is cold) and torque them all to 85.
This is basically what I did.
Old Jun 24, 2005 | 06:04 AM
badlooser's Avatar
yes I retorque after 2-3 hard runs on race fuel.
Old Jun 24, 2005 | 07:20 AM
GOKOU's Avatar
Lightbulb
Thanks alot. Alky kit going in soon so I need to upgrade the head stud. Hope all goes well with the install.
Old Jun 24, 2005 | 08:19 AM
A418t81's Avatar
Now you see why I didn't put studs in my car. After reading all the different methods, torque specs, retorquing, not retorquing, head-off, head-on, etc, etc, I was a bit on the annoyed side. There's a circus of info on this subject and it needs to be somewhat standardized before I throw these in my car. Also, the efficacy of the studs is something I question as well.
Old Jun 24, 2005 | 09:13 AM
GOKOU's Avatar
Agreed and this was the reason I did not put them long ago and still debating but wanted to make sure what needs to be done if an attempt was made .
Only reason I'm debating on stud is due to the alky kit or else no upgrade for me.
Tobra
Lancer Tranny/Drivetrain Tech
Jun 3, 2017 08:17 PM
backyardevo8
Jun 15, 2016 03:44 PM
Farga
Pacific Northwest
Mar 20, 2012 06:46 PM
philamthebest
Mitsubishi TC-SST Discussion
May 11, 2009 08:01 PM
d3wu
11
Apr 8, 2005 11:34 PM
