Clatter noise
Old Jun 29, 2005 | 03:30 PM
TxEvo8's Avatar
I have an '03 with 32k and have recently noticed the same noise, but only in 5th gear when I let off the throttle. I will have Mitsu look at it when I take the car in for some warranty work and post the results.
Old Jun 29, 2005 | 03:36 PM
mooreboost's Avatar
I've got the same exact problem in my '03 with 19k miles.
Old Jun 29, 2005 | 03:37 PM
Rushin's Avatar
yup.. same problem, gets louder with ac on.
Old Jun 29, 2005 | 03:41 PM
hkfeet's Avatar
Chatter noise went away on my car after uprading to a act clutch/prostreet flywheel
Old Jun 29, 2005 | 03:47 PM
w evo's Avatar
I have a 03 with 19k that makes the same noise. Im pretty sure it is the TOB. Almost everyone I talk to says some noise from the TOB in neutral with the clutch pedal out is no big deal.
Old Jun 29, 2005 | 03:53 PM
budlong's Avatar
same noise on my 03... especially when the AC is on..
BUDLoNG
Old Jun 29, 2005 | 06:18 PM
KazzEvo8's Avatar
but it can be loud(ish) and constant ... noticeable on decel, etc. ...
Old Jun 29, 2005 | 06:19 PM
sr20det91's Avatar
Its the TO bearing. If you notice, it goes away with the clutch in.
Old Jun 29, 2005 | 06:35 PM
EvilBlueEvo8's Avatar
i have the same noise. actually had the car in neutral today in the driveway and got out of the car and listened for it. its loudest near the passenger front wheel. mine also goes away with the clutch pushed in and comes back when i let it out.
Old Jun 29, 2005 | 10:16 PM
AustinEVO's Avatar
It's just clutch chatter, shouldn't be a big deal. Seems most Evo's have it as does mine. Every single friend of mine with a stock clutch has clutch chatter. I've had clutch chatter now since ohhhhh, well for the last year and a half. I wouldn't stress out over it.
Old Jul 1, 2005 | 08:43 AM
SpecVSpeed's Avatar
Judging by the number of people who have this sound Im not gonna worry about it......Ill just keep an ear open to make sure it doesnt get louder.....
Old Jul 1, 2005 | 08:52 AM
imaboa's Avatar
I mentioned this same problem to a friend of mine with an eclipse. It is definitely TOB, he said he took his to mitsu to see about having it changed under warranty, and they wont change it b/c its just noise. He said they updated the bearing on the 03+ eclipse.
mine is an 03 with 25k on it. same noise...
just leave the clutch in all the time, or turn up the radio.
Old Jul 1, 2005 | 09:00 AM
NEMES!S's Avatar
dont worry its just clutch noise, wait till you put an aftermarket one in, especially an un-sprung disk
Old Jul 15, 2005 | 06:46 AM
honki24's Avatar
i just posted another thread about this b/c I got worried too... I'm sure this sound just started recently. Gets louder w/ A/C, goes away w/ clutch in, now try this, go under your hood and blip the throttle, it is much louder after you do. Here's the video I took of it, tell me what yall think. Someone on my thread said that everyone told his friend it was the TOB, but it turned out to be a couple loose bolts on the flywheel (which has me worried)
its 4MB, might wanna save as
also might wanna save as if it doesn't work for you by clicking it...
Old Jul 15, 2005 | 06:52 AM
EvoTech's Avatar
Much more likely to be TOB noise than loose flywheel. I have talked to a lot of experts about this and my conclusion is that it is nothing to worry about.
