burning oil
Old Jun 23, 2005 | 12:46 AM
jxs1984's Avatar
burning oil
so i'ved searched and read many threads about oil consumptions...
i travel far everyday, and drive hard. cruised on long trips 600 miles. so is it because of how i drive everyday is the result of burning oil?
before my 2nd oil change, it had low oil readings...
monday i am due for my 3rd oil change - 10k service... i checked the oil today and it reads very low.
few people recommends an oil catch can... any other ways to prevent large loss of oil? should i use different kind of oil or stick with mobil 1?
Old Jun 23, 2005 | 02:52 AM
Devbo's Avatar
well i cant tell you anything without speeking ignorance the only thing i can say is, mobil one is some of the best stuff you can buy
Old Jun 23, 2005 | 04:14 AM
High Voltage's Avatar
An oil catch can will probably be the best solution. If you're losing oil then the type of oil you are using won't make a differance, you'll just lose it.
Old Jun 23, 2005 | 04:55 AM
silvery_eagle's Avatar
just check ur oil every 2000 miles... refill a bit if needed
Old Jun 23, 2005 | 05:44 AM
money pit's Avatar
I checked mine yesterday and with 3500 miles on it, I was down about a quart. My dealership wont allow me to use the free maintence untill around 4500 miles. I figure i'm due for my first oil change, I might have to place a call to complain.
Old Jun 23, 2005 | 05:46 AM
DCSilvrEvo's Avatar
Did you check on a flat service?
Is your drain plug leaking?
Turbo oil lines leaking?
SURE there is Synthetic oil in there?
I dont burn oil @ all between oil changes.
Old Jun 23, 2005 | 09:19 AM
bolsen's Avatar
A catch can? WTF? A catch can is going to do exactly that... catch it! Not put it back into the motor!
Are you blowing smoke? Leaking? Any power loss?
Old Jun 23, 2005 | 09:27 AM
Thegame's Avatar
My car is also brand new and I think I'm consuming oil as well. I do have a catch can and that's where some of it may end up, but not a 1/2 quart. I will check for a leaking drain plug, but as far as I know I'm not blowing smoke nor leaking anywhere. And I did the conservative break in for about 1,000 miles at least. I don't think I felt boost until about 1,200 miles. So you can throw the break in theory out the window. From what I've been told, unless you burn more than 1 quart every 1,000 miles it's considered normal. One other thing I was thinking is that I dont think there's a whole lot of "space" between the two marks on the dipstick. I think between the two it may only be about 1/2 quart.
Jadeinc.
Sep 13, 2015 08:35 PM
febs1011
Sep 4, 2015 03:28 PM
Kkamshi
Aug 18, 2013 08:03 PM
csmith82177
Feb 22, 2011 07:12 PM
ImsoevoX
Oct 24, 2010 05:02 PM
