Which cams should i get?
Old Jun 23, 2005 | 10:59 PM
IDRINKV8's Avatar
Talking Which cams should i get?
I want to get cams that will give me a nice midrange powercurve. I heard gsc cams are great and HKS also but which ones for my application. Is there anything else i need to do before i put cams in.
thanks alot guys
Old Jun 24, 2005 | 01:41 AM
aps's Avatar
aps
Maybe you should buy cam gear and valve spings too.Make your decision to 264/272 or 272/272.
Old Jun 24, 2005 | 09:06 AM
GregGSC's Avatar
what turbo are you going to run? stock with great mid range power I would suggest going with the 264/264. the only thing you really need to get is head studs. if you go with 264/272 or 272/272 get some cam gears.
greg
Old Jun 24, 2005 | 09:29 AM
evo8_m3's Avatar
currently have 264's on mine... but looking to go with 264/272 as I feel like I need more top end. Yeah. definately change the headstuds while you at it and valve springs if you have extra $$.
Old Jun 25, 2005 | 10:33 PM
IDRINKV8's Avatar
when you say you need more top end though what do you mean does that mean you have less top end then the stock cams or you want more top end in general which cam does what in terms of power i know the intake cam and exhaust cam functions but which cam suits which need like the 264's are for mid range but 264/272 is for top end what would happen if you had 272/272 cams
Old Jun 25, 2005 | 10:34 PM
vegasboy301's Avatar
264/272
Old Jun 25, 2005 | 10:42 PM
IDRINKV8's Avatar
what do the 264/272 cams give me mid and high end right?
Old Jun 25, 2005 | 10:47 PM
yeah. its like a ballance.. or something.
Old Jun 25, 2005 | 10:48 PM
sleet's Avatar
272s or 280s, Go big.
Old Jun 25, 2005 | 10:52 PM
280's require more things you have to buy to safely run them
Old Jun 25, 2005 | 11:00 PM
IDRINKV8's Avatar
no doubt so im gonna go with the 264/272's thanks for the info
Old Jun 26, 2005 | 03:27 AM
aps's Avatar
aps
Np.Please share your experience after install the cams.
Old Jun 26, 2005 | 08:50 AM
Z1 Performance's Avatar
264/272 is the best overall combo for these cars...you dont "need" anything else to run them safely, though headstuds are a highly recommended mod to install at the same time
As for cam gears, unless you have a standalone, I'd personally skip them - the 264/272 combo works great without gears at all, and the idle is still very stable.
We also happen to have a bunch of 264/272's in stock...see our thread in the vendor classifieds seciton
adam
