evo pistons
Old Jun 28, 2005 | 12:49 PM
evoego's Avatar
Registered User
evo pistons
I have neard that the Evos were made with 3 different pistons...like an A B or C...the car has either of the 3 but not both, and wont work intermatched...can someone else chime in on this with any info as I have never heard of this before now...thanks
Old Jun 28, 2005 | 12:53 PM
Compjoc's Avatar
I've never heard of that. Maybe different model evos, like the evo 4 pistons wouldn't work in the evo 8.
Old Jun 28, 2005 | 12:55 PM
evoego's Avatar
Registered User
no i was told this for Evo 8 only...03 model to be exact...doesnt make since to me since all come with same compression and such...more comments please
Old Jun 28, 2005 | 02:38 PM
evoego's Avatar
Registered User
bump for another answer
Old Jun 28, 2005 | 06:07 PM
evoego's Avatar
Registered User
anyone
Old Jun 28, 2005 | 06:18 PM
plokivos's Avatar
i think they have 2 different turbo models in japan, but pistons shouldn't be any different.
maybe there are difference between earlier model evolution and current line up.
Old Jun 28, 2005 | 07:49 PM
evoego's Avatar
Registered User
plok pming you now...or get on AOL IM please
Old Jun 28, 2005 | 07:51 PM
plokivos's Avatar
i'm on aim now
Old Jun 28, 2005 | 09:01 PM
plokivos's Avatar
Default Re: Evo Piston
There are 3 differnet pistons letters ( A,B,C) You find the which one fits his car by looking on the bottom right corner of the block where the oil pan is. It will be marked
I=piston type A
II= piston type B
III= piston type C
Old Jun 28, 2005 | 10:22 PM
timzcat's Avatar
This is true but the size difference is very small. If you are replacing pistons then you would be honing the cylinders anyway and you can adjust for the different size. And the same engine can have any combination of the 3 in it from the factory, but it is usually all the same or one hole is slightly larger.
Old Jun 29, 2005 | 06:10 AM
Z1 Performance's Avatar
it goes by bore size as I recall.....whoever is building your motor will be able to reorder the right one, assuming your piston wall is damaged to the point that it cannot be honed to the larger of the offered sizes
Old Jun 29, 2005 | 07:22 AM
evoego's Avatar
Registered User
I am posting this because my motro burnt up a #4 piston and the dealer is gonna fix it...they say the B piston which my car has is on backorder for several weeks, been waiting 8 weeks already...The cylinder wall has no damage but will prob be honed anyways...so what you guys are saying is I could put one of the A or C spec pistons in there with no problems??? these are in stock everywhere...Let me know please as I am beginning to loose my head over this...
Old Jun 29, 2005 | 07:31 AM
nastyevo8's Avatar
good luck.
Old Jun 29, 2005 | 07:34 AM
evoego's Avatar
Registered User
thanks its been approved to fix but I am getting the run around about the piston...
Old Jun 30, 2005 | 12:01 PM
WRX 2 EVO's Avatar
good to know...
A.Ekstrom
Oct 14, 2008 07:09 AM
Perk77
Aug 28, 2008 07:59 PM
jamie_v1
10
Aug 5, 2008 01:16 PM
Aby@MIL.SPEC
10
Nov 13, 2007 08:11 AM
Aby@MIL.SPEC
Apr 26, 2007 06:55 AM
