would switching the two vaccum lines on my MBC do anything?
Old Jun 28, 2005 | 10:54 PM
Sap12687's Avatar
i know they would but i had to lure you in with the stupidity of the statement.
Switching from a TurboXs to a Hallman and the lines are exact oposites on each boost controller.
TurboXs' bottom line runs to my wastegate actuator and the side line runs to a pressure source right above the actuator (what is that by the way?) Hallman instructions say the bottom line should run to the pressure source and the side should be the actuator.
.....im confused, my car runs perfectly fine and holds about 21 psi. Are my lines switched?
Old Jun 29, 2005 | 12:30 AM
evo81's Avatar
i've done installs on both mbc.they are different.hook up the hallman way.the other way will spike or just won't hit full boost
Old Jun 29, 2005 | 08:02 AM
bolsen's Avatar
Yea a friend of mine just ran into that... hook it up the way hallman says.
Old Jun 29, 2005 | 08:21 AM
MalibuJack's Avatar
Yep.. consider that there's a ball-spring valve in there.. It needs to be hooked up the right way so the valve will even open correctly.. plus most MBC's are also ball-spring valves (Grainger type valves) and the outlet side to the wastegate has a small 'weep hole' on it to relieve residual pressure... restrictor valves are different (think of a fuel/water petcock) where it doesn't matter which way it hooks up, but those valves don't offer the amazing boost response and spool that a grainger style valve will offer (since it restricts at nearly 100% until its spring pressure is overcome by boost pressure)
Old Jun 29, 2005 | 07:37 PM
Sap12687's Avatar
excellent thanks for the responses
Old Jun 29, 2005 | 09:39 PM
RREvo's Avatar
Yeah what he said .
EvilDSM97
Feb 2, 2017 10:51 AM
soldave
Feb 8, 2013 03:26 AM
nonojoe66
Oct 27, 2009 10:47 PM
AfireINSIDE
Apr 6, 2006 05:34 AM
raywong
May 4, 2004 07:53 PM
