how to achieve 400WHP on pump gas...
my thoughts exactly, but I would go with a WR from switzer.
Originally Posted by 3240
You're crazy to run a GT35 if you only plan on running 91 octane. It will be laggy and no fun to drive. The GT35 turbo really comes alive at higher boost which you can't run with 91 octane. Get yourself a Bushcur stage4 (or equivalent) with a smaller turbo and you'll have a great daily 91 octane driver.
He wants 400awhp (not 400 hp) on 91 octane without alky, big difference.
Originally Posted by kiddevo
Post dyno #s after u get car back to shut every one up
joke
I'm thinking about alcohol kit for my car too but it's not just spraying and make more power. Mixing alcohol in the engine compartment is like playing with fire, some safety concern need to be addressed and so far none.
Originally Posted by onesicklambo
...is im going to be driving/racing my car ALOT, go out to the local ricer hang out and race...drive down to the local raceway(50miles) and race, i want to have this power(400WHP) available AT ANY GIVIN TIME, doesnt matter if im at a astoplight or on the track. Yes on some occasions i will run higher octane(91/100mix) but 99/100 times im in my car i will probably not want to go through the hassles of filling up with race gas, and stuff. Its just i guess "conveinent"? for me to want to make this power on 91 so i can go out drive regualr and have the power i want. sorry if im confusing.. lol
...If i can make over 400 with those turbos..how about the one i have? i dont knwo too mcuh about it except people tellling me to upgrade. lol and what do you suggest as far as boost levels before pulling timing.. running pump(91)? like maybe 23 at the highest?
If you're going to go with alky (good choice for what you want to do with the car), then I would say go with a GT35R and call it a day. You'll easily make more than 400whp (more like 500) and you should be able to stomp the local ricers all day long.
l8r)
Do you have a dyno sheet that you can post? It's not that I doubt your HP claim but I'd like to see the power curve on this setup with 91 octane. Thanks.
Originally Posted by G20
Sure! Here is the lowest dynoed for 91 oct that I did at Tuning Technologies here in So Cal. The boost is around 22 psi and not finish tuning the SAFC-II on this dyno yet. We were having problem later when tune the boost higher to 26-27 due to spark-plugs gap (maybe) and maybe the stock-turbo dynoflash (just maybe). The car was pulling timing with higher boost so I need to identify the cause. I just fixed some bad gaskets and will come back for another run next week before heading to the drag. But running 91 oct daily with 22 psi on GT35r is so much fun and no problem at all. Don't let some "other" guessing confusing you.
It will be interesting to see what his setup (twin charger) will do on 91 octane:
http://www.we-todd-did-racing.com/wetoddimage.wtdr/wOTc4NTc0NnM0MTNkZmQzMXk1NDE%3D.jpg
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Originally Posted by robertrinaustin
Are you sure the graph if whp? I looks to be SAE corrected.
Trust me, I'm not confused. Look at my thread from last year entitled "pump gas power." Do a search and you'll find it. 472awhp on 91 octane without alky using a smaller turbo than you. Again, my point is if you're not going to run C16 (high boost) you do not need a GT35. Also, this same setup put down 600awhp on C16 and ran 11.4 @124mph at Bandimere in colorado 5800ft absl. No guessing here.
you can get close to 400 horses on the wr the 3071 or if you're greedy the 3076 or 3037. that answers the question...
I'm just try to show that the 400 WHP is achievable on 91 oct gas as oppose to some mentioned that it cannot be done. It's also mean to help the original poster of the thread that his turbo is capable of hitting 400 on 91 oct. too since it's very close to the GT30 & GT35Rs.
I'm using my car for drag a lot so YES! I do use race gas when it needed. And for the turbo, a little different in size doesn't mean it'll perform better than the other, the tuning, the parts and the condition of the car play a very important role. I'm using SAFC so not much control I have over the tuning but I want to see with a simple setup and easy tuning, what can it achieve on the EVO.
FYI, the 600WHP car you mentioned above, it's kind of slow for the number that it ran for that kind of power.
I'm not trying to get into any debate over hps here. Your car has more power then it's great for you. I'm still in the process of building and tuning my car.
Remember 600awhp is altitude corrected using a 1.25 correction factor. At this altitide my turbo made a max of 28psi (same turbo makes 34 psi at sea level). When we dyno'd it at sea level it was back up to almost 600awhp uncorrected. So the 1/4 times that I posted are actually very good, 124 mph is amazing at Bandimere in a car weighing 3300 lbs. In other words, you're wrong.
