Stuck at 610 WHP!!!
Old Jun 29, 2005 | 09:31 PM
TomeiEvo's Avatar
Its going to a drag meet this Saturday, we'll see if she runs below 10.41 this time..
Old Jun 29, 2005 | 09:34 PM
3000ways's Avatar
The true test of power will be in the trap speeds. I mean I just think that is the best way to test a cars power. Dynos can be so inconsistent IMO, and people look into them way to much.
RREvo's Avatar
10 hp more with 50 hp shot is just weird .
Old Jun 29, 2005 | 09:39 PM
jj_008's Avatar
A GT35R is rated up to 600hp at the crank according to Garrett. It looks like you have maxed out the turbine wheel. A GT40R maybe what you need.
Old Jun 29, 2005 | 09:41 PM
EVOONYOASS's Avatar
That does sound very strange indeed. What kind of head work has been done? Maybe the head is holding you back. What compression?
Old Jun 29, 2005 | 09:44 PM
TomeiEvo's Avatar
Using standard corrected the figure comes out to 632 WHP... the 608 earlier was uncorrected using sae.
Head's a 1st gen head running 8.5 compression...fully ported and running 1 mm oversized valves..
Still with nos, shouldn't it just run more??
Old Jun 29, 2005 | 09:47 PM
plokivos's Avatar
i think with c16, the n20 doesn't really make dramatic difference.
Old Jun 29, 2005 | 09:50 PM
EVOONYOASS's Avatar
Well I believe an AMS Evo made around 630whp and then around 660whp spraying. I think that was on a 2.3l stroker so maybe this is about right.
I would have the head flow tested and see whats going on. You never know.
Old Jun 29, 2005 | 09:51 PM
EVOONYOASS's Avatar
Old Jun 29, 2005 | 09:55 PM
TomeiEvo's Avatar
Will go down this Saturday to check it out what times I;m doing first...
Old Jun 29, 2005 | 09:58 PM
TomeiEvo's Avatar
Anyone has experience using the Forced Performance T67 or FP3575? Wonder if that will make more for me??
Old Jun 29, 2005 | 10:30 PM
nickracer9's Avatar
try a larger a/r exhaust housing.
Old Jun 29, 2005 | 11:05 PM
TomeiEvo's Avatar
If you've read my first post, I have already done that, did nothing for hp, made the spool so bad that you get full boost close to 1000 rpm later...
Old Jun 30, 2005 | 01:20 AM
TomeiEvo's Avatar
But I forgot to add this, I've retarded 3 deg in timing on the 50 hp nos, is this too much? Should i just leave at no retard??
Old Jun 30, 2005 | 01:25 AM
Widebandphillip's Avatar
Your turbo is maxed out, time to swap to a bigger one.
