Stuck at 610 WHP!!!
Old Jul 4, 2005 | 08:47 PM
  #61
TomeiEvo's Avatar
Have you tried a GT 35R and whether 610 WHP ( turbo only) sounds bout right?? Cause I will go ahead with the T67 if thats the case.
Old Jul 4, 2005 | 09:00 PM
  #62
topnotchevo's Avatar
no, but i heard thats about all u can get out of a gt35r,615 or so. i know the t67 is more laggy than ur gt35r,but that t67 will pull her harder n faster..200mph in no time!!!
Old Jul 4, 2005 | 11:34 PM
  #63
fre's Avatar
fre
Originally Posted by topnotchevo
power comes on at 3800hits topboost at 5500 and holds it steady to 8000rpm.at low boost i`m at 450whp@20psi on 91 octane and 650whp@28psi,we`re going to 35 psi w/ c16 within the next 2 weeks.should be dyno tuned at 700+whp.its all aem controlled 2 step n nos to help on spool up at the track.it spools very big power ,thats what i wanted.should run in the 9`s at sea level,to hot now in phoenix..110+..
wtf? 200 hp gain off of 8psi? Did you do something else? I gained about 95hp from 9 psi gain.
Old Jul 5, 2005 | 12:09 AM
  #64
TomeiEvo's Avatar
Not surprising considering you gain up to another 40 hp on race C16 fuel alone at the same boost. More timing at big boost levels = big power!!!
Old Jul 5, 2005 | 12:22 AM
  #65
fre's Avatar
fre
I guess that's true. I can't adjust timing so I'm stuck at about 19 degrees. I only run 100 octane though, because I don't see any gains running 110 or 116 due to not being able to mess with timing. If I ran 30+ psi I would probably go with 110, but I might as well stick with unleaded since it seems to run fine at 28psi and 12-12.5 af ratios.
Old Jul 5, 2005 | 08:55 AM
  #66
timing and fuel=h.p...I know the heat treatment of the engine helps alot.She runs way cooler than any other turbo car I`ve seen.
Old Jul 11, 2005 | 02:40 AM
  #67
ShaunSG's Avatar
Dixon, do let us know when you solve the problem and share what the cause was ok? An unusual, hence interesting problem.
Cheers and good luck
Old Jul 11, 2005 | 03:52 AM
  #68
SaabTuner's Avatar
Originally Posted by DynoFlash
The injector time is a good indication of what is going on. When you make changes if you dont need more fuel you are not making more power.
One of the cases where it would be nice to still have a MAF sensor someplace. (Like a big 4" LS6 one) More air-mass/sec = more power ... assuming everything else is equal anyway.
For now, unless there turns out to indeed be a boost leak, I'll subscribe to the turbine being the weak link. I don't think the exhaust gas pulses are hitting the turbine with enough force to push any more air through the compressor. Twin scroll with a larger turbine wheel might solve the problem ... maybe ...
Adrian~
Old Jan 8, 2006 | 01:17 PM
  #69
deee's Avatar
never heard the high horse power like this in Malaysia... Can u show the dyno graph? where u done the dyno? How u find the C16 in malaysia? they are very strict about fuel imported.....
Old Jan 8, 2006 | 01:23 PM
  #70
giumela's Avatar
you are 2 greedy...you say you're stuck at 610whp...it's kinda like someone saying I died and now I'm stuck in heaven....Evo's are not for drag racing....
Old Jan 8, 2006 | 01:56 PM
  #71
ct9a gsr's Avatar
What's wrong with wanting more power? There's no such thing as "too much power"... and its certainly not a bad thing to be greedy when it comes to power with cars.
BTW, this thread is very old... and revived randomly from the dead.
Old Jan 8, 2006 | 03:27 PM
  #72
JohnBradley's Avatar
Its a stock headed motor. Try porting the head and letting more air in. The ports have become the restriction at that point it sounds like. Air=Power. If more air (psi) is not making more power, then it means that CFM is limited somewhere in the system, this case its not the turbo. Even with nitrous he wasnt making more, I would put a fair amount of money on stock ports.
Old Jan 8, 2006 | 04:58 PM
  #73
alloyic_rs's Avatar
i was thinkin the same thing, i mean cmon, 610whp from an evo is already a TON of power from that lil engine
Old Jan 8, 2006 | 09:13 PM
  #74
EVOONYOASS's Avatar
....holy old thread!
So because he tried to add horsepower and something is wrong with his car, he shouldn't ask for help? This is an evo forum, right?
Let the man ask questions, he is trying to figure out a problem and people are willing to help him.
Old Jan 8, 2006 | 09:20 PM
  #75
TEXSRT4's Avatar
sounds to me like you have maxed out somthing! restriction somewhere. i know similar things were happening in the srt community. guys would add boost, but wouldnt get any more power. added timing, same. what we eventually found out was that the intakes made by one of the vendors just couldnt flow enough. when they swapped out to a better brand, the power jumped through the roof! check for the restriction. it could be intake, exhuast, cams, head, etc
