TSB's for 03 tranny issues?
Originally Posted by KILTERMAN
Now when you go In complaining of the the grinding or rough shifting , and they arnt able to replicate it , then what?
Not exactly....take your car in....and have the problem documented even if it cannot be duplicated. Then if the problem gets worse you can use the "good faith" warranty to get it fixed.
i had the same grind over 4k rpm from third to fourth.
the dealership replace 3,4,5 syncros and 3,4 gears becausethey said that the gears were broke.
The car is better but i now can feel the gear grind slightly when i shift in all gears, i can't hear but i didn't know if that could be a clutch going bad or if that is just how mitsu cars shift.
Originally Posted by taenaive
I have the problem with my 5th gear too. and this is 4 months old 05 evo.
it only grinds above 4k rpm. is this normal? does TSB say anything about 05 evo?
If you read the manual it says that the sychros will grind, especially in 2nd gear before the fluids warm up ... a lot of guys have put BG synchroshift or Pennzoil sychromesh tranny fluid to get rid of their 2nd gear grinds, its worked for them ...
I have a grind at high rpm going into 5th gear as well. However, I doubt I will ever have anything done about it because I am too afraid Mitsu will F something else up while they are in there and my car will be worse than it is right now. All of my other gears are good to go.
got all my synchros replaced under warranty, pretty str8. not only that, but i had them install my ACT clutch costing me only 1 hour labor since most of the labor was being covered by the synchro job...ahhh what a scheme
Originally Posted by dafarmer69
i only have a copy of the the tsb for 2nd and 4th..
I just started getting a grind in 5th....it's only when I am accelerating hard though. Do you think I should go to Mitsubishi right away? Or should I wait? Im going to have to get them to crush it on the highway to get them to duplicate it....what do you guys think??
