striped out turbine housing
I installed my megan racing manifold striped out the bolt on the turbine housing and im tryin to figure out my options. HElp me please!!!
Three choices. Drill out the remaining threads and tap with appropriate size tap (read not the same size), drill it out and heli-coil it or buy a new turbine housing.
jk on the third one.
jeff
jk on the third one. jeff
A helicoil is a thread repair kit which will allow you to use the stock bolt. It comes with a tap and a new insert that will thread into the existing bolt hole. When you buy the helicoil kit it will list a specific drill bit size that you will also need to buy.
First you drill out the old threads from the stripped hole with said drill bit. Then tap the hole with the tap provided in the kit. Next thread in the insert with the special tool that is provided and that's it. Reinstall turbo with new stock bolt.
jeff
jeff
Originally Posted by ebbeast2005
whats helicoil? I put the stock mani on and its not leaking without the bolt. I guess im going to look at new turbos. Whats a good turbo for around 1k
it's going to be a big pain in the *** trying to drill that housing as the metal is very hard. I had to use multiple hardened drill bits. You need to start with a small drill bit and work your way up and also use some lube for the bit as it will get very hot very quick.
bryan
bryan
Actually a 10.5 hotside would. The exhaust manifold bolts up to the hot side of the turbo, and the stripped hole you're talking about would be in that cover.
If you're looking to get away really cheap, I have my old 9.8 turbine housing from when I switched my car over to a 10.5 hotside.
its a good reason to buy a new turbo tho. i dont have cams so its either hotside and cams or turbo but i have no clue which turbo or what the shop recomended the bolt on percision 50 trim whatever that means. im turbo stupid and i really want to learn and searching the fourms isnt helping much
FS[SouthEast]: FP Green 73HTA - Great Condition
tsitalon1
Sep 18, 2016 12:13 PM
