serious boost fall off
Old Jul 3, 2005 | 09:34 AM
sgtevo's Avatar
serious boost fall off!!!!
I just got my 05 back from a regular service and now it seems that at 6k the boost falls further down to 10psi it never use to do this before. The car is completly stock except for a hallman set at 20psi. i know that there are alot of gurus out there so if you can give mee some input it would help out alot
Old Jul 3, 2005 | 09:50 AM
sgtevo's Avatar
please help me out guys
Old Jul 3, 2005 | 09:55 AM
eve-slow's Avatar
If you installed the controller yourself, check all of your hoses again and make sure the stock solenoid is capped off. Did you have 20 psi before the service?
Old Jul 3, 2005 | 09:57 AM
Curt@MrLed's Avatar
Former Vendor
ditto.
Old Jul 3, 2005 | 09:58 AM
sgtevo's Avatar
yeah i did and it would do the regular taper about 2-3 psi by redline
Old Jul 3, 2005 | 10:01 AM
althemean's Avatar
MBC with taper?? I thought that the whole purpose of the MBC was to eliminate that/as well as give you control of boost settings.
Old Jul 3, 2005 | 10:02 AM
sgtevo's Avatar
ill go check the lines again but im pretty sure that they are on because the service was only for an oil change and i did have the lines capped
Old Jul 3, 2005 | 10:03 AM
sgtevo's Avatar
i thought so too but the mitsu ecu some how still does its thing
Old Jul 3, 2005 | 10:05 AM
sgtevo's Avatar
Originally Posted by dafarmer69
ditto.
yeah i did. help
Old Jul 3, 2005 | 10:06 AM
sgtevo's Avatar
it was fine before the service
Old Jul 3, 2005 | 11:05 AM
sgtevo's Avatar
Smile
Ok i checked my lines, went for a test drive and got a distinctive pop. I now believe that it is an IC piping problem. Its raining now so ill get back to you guys later. Thanks for the help guys ill keep you posted.
Old Jul 5, 2005 | 05:28 AM
inariv5573's Avatar
Get a reflash with it.
Old Jul 5, 2005 | 03:55 PM
sgtevo's Avatar
It was a loose ic pipe. so the car pulls ok now but i do plan to get a flash.
Thanks again guys i appreciated all the responses.
Old Jul 7, 2005 | 08:14 PM
ebbeast2005's Avatar
hose def. i had same prob. went to auto zone bought all new lines and boosting 24psi....i have to change every few months tho for some reason
