New Forge RS BOV
Old Sep 19, 2005 | 03:16 PM
  #211
taenaive's Avatar
it sounds good when you are boosting high.
but you will have the rattle snake sound when you do partial throttle.
Old Sep 19, 2005 | 03:20 PM
  #212
Eveolicious's Avatar
Ahh... so when "grandma driving".. u will get the rattle snake..but when driving harder, and boosting you will get the "whoosh"?
Even if I am stock I will get these noises, correct? (The "rattle snake" when not boosting, and then the "whoosh" when boosting)
Old Sep 19, 2005 | 03:40 PM
  #213
taenaive's Avatar
yes!
BTW, I am kinda getting used to this low fluttering sound.
Old Sep 19, 2005 | 04:11 PM
  #214
hkfeet's Avatar
Anyone else scratching the top of the valve adjusting it? Im really scratching the heck out of it due to the radiator shroud because I keep forgeting how close it is to it.
Old Sep 19, 2005 | 04:37 PM
  #215
yes!
Alright cool!
I need a couple paychecks, and then I will probably get that valve!
Old Sep 19, 2005 | 04:43 PM
  #216
GOKOU's Avatar
Can you post a picture of where your valve is? That could be helpful
Old Sep 19, 2005 | 05:37 PM
  #217
hkfeet's Avatar
Sure np, but its just at the same location as the stock bov since I am still using the stock airbox and stock uicp.
Old Sep 19, 2005 | 06:07 PM
  #218
GOKOU's Avatar
I see. I have BR upper pipe so there is no problem. Not sure if you can zip tie yours or not.
Old Sep 19, 2005 | 06:24 PM
  #219
hkfeet's Avatar
Heres a pic. Eventually I would like to have it mounted on a uicp but too bad the top is scratched up.
Old Sep 19, 2005 | 06:33 PM
  #220
GOKOU's Avatar
That does look bad. Maybe you can use some kind of sticky foam or spacer between the bov and fan strud to prevent it from rubbing.
DO you have a mbc? Are you sourcing the vaccuum from the turbo inlet? DId you experience any fluttering with this bov?
Thanks.
Old Sep 20, 2005 | 01:59 PM
  #221
hkfeet's Avatar
Well lately I had the tension set real tight, almost max to see what kind of boost my car can make with my xede maps, and it does flutter at partial trottle lift. I havent experienced any fluter with the way I had it set before at a loose tension.
But honestly, every valve, stock, jdm mr, old forge, fluttered on me. I changed my driving style and just lift off completely instead of slowly when Im on the highway.
Does yours flutter just everytime you let off the trottle?
Old Sep 20, 2005 | 02:12 PM
  #222
taenaive's Avatar
yeah, I never got any flutter issue with recirc set up.
I just verified that rattle snake with VTA was normal. and it is very different from the real flutter.
Old Sep 20, 2005 | 03:28 PM
  #223
EvoTio's Avatar
Well lately I had the tension set real tight, almost max to see what kind of boost my car can make with my xede maps, and it does flutter at partial trottle lift. I havent experienced it the way I had it set.
Did you notice that you were able to squeeze some more boost by setting the tension tighter? I am at about 24 clicks and my RS valve is not having any adverse affects on my motor. I am wondering how much tighter I can go on my valve. On my Xede I am getting a 23 PSI spike and then it tapers to 18 PSI. After my car warms up the boost goes to about 21 then to 18 PSI. It may also be the new SMART system I have that mabe pulling my boost back. I'll have to keep experimenting.
Old Sep 24, 2005 | 10:12 PM
  #224
taenaive's Avatar
I just switched my valves to recirc type of valve But still VTA setup. And, it fluttered!
I was like WTF? VTA doesn't work for forge RS bov?
Then, about 1 minute later, it all started to work just like my previous recirc setup...nice and smooth. Now, I think lubrication was the problem for the VTA type of valve. When I pulled my recirc valve, the grease was gone along with the vavle!
You guys with the problems should try to get good lube and apply on your bov. I used CV joint grease. But, any grease will do the job. I bet forge fogot to put much grease on your bovs.
Old Sep 24, 2005 | 10:19 PM
  #225
taenaive's Avatar
I am going to try lube the valve again and try. that low flutter could be just a lubrication problem.
Rattle snake! go away!
