Intercooler installed..Boost dropped
Old Jul 4, 2005 | 11:18 AM
Mayhew333's Avatar
Like the title says, I put in a nisei intercooler last week and noticed thatmy boost dropped from 21.5 to about 19.5-20. I think I heard that its normal due to a colder charge but I just want to be sure. Is that normal?
Old Jul 4, 2005 | 11:22 AM
Kwman's Avatar
Yes, you have a bigger IC so you'll get a little pressure drop. Just turn the knob on your MBC and its all gravy.
Old Jul 4, 2005 | 11:31 AM
mooreboost's Avatar
Agreed, larger IC's will have a slightly larger pressure drop.
However it does slightly lean out your mixture, but I doubt it's enough to worry about. So I would just increase boost like Kwman stated and you should be good to go.
Old Jul 4, 2005 | 09:20 PM
Devbo's Avatar
+1
Old Jul 5, 2005 | 12:28 AM
marksae's Avatar
The larger intercooler will have more volume to fill, so your boost control settings will need to be changed in order to run the previous boost levels.
Old Jul 5, 2005 | 12:46 AM
plokivos's Avatar
boost it up to 23! what's the problem?
Old Jul 5, 2005 | 07:53 PM
David Buschur's Avatar
The information above is NOT correct. A good intercooler core that is larger will have LESS pressure drop than the stock intercooler, not more.
Our intercooler kit for the EVO will gain boost compared to the stock unit, that is if it is installed without any leaks.
Go back and double check all your connections on your intercooler, make sure you don't have a leak, you shouldn't have lost boost.
David Buschur
www.buschurracing.com
Old Jul 5, 2005 | 08:16 PM
scott88vr6's Avatar
David Buschur
I didn't lose any psi when I installed my BR Intercooler Boost was more responsive. I didn't have to turn anything up.
Old Jul 5, 2005 | 09:47 PM
AzNeVo8's Avatar
david just took yall back to school ouch...........no offense
Old Jul 5, 2005 | 11:04 PM
mooreboost's Avatar
He is right that a *good* core should have less pressure drop. However I am almost positive that it is possible for a sub par core to create a larger pressure drop.
Old Jul 5, 2005 | 11:31 PM
nickracer9's Avatar
my boost went up with the nisei.
Old Jul 6, 2005 | 10:37 PM
Mayhew333's Avatar
So I should actually be making more boost since there is less pressure drop. I am going to look for leaks..it's probobly my lower piping or possibly the weather?? yo
Nickracer9, ow much did your boost go up? (mods)
Old Jul 6, 2005 | 10:44 PM
use2vtec's Avatar
When I installed my BR intercooler I lost a couple of pounds. I checked for leaks and everything seemed good to go so I just turned it up and the car has been driving great for the past 4-5 months.
Old Jul 7, 2005 | 12:46 AM
Mayhew333's Avatar
Word
Old Jul 7, 2005 | 07:30 AM
With a GOOD core, GOOD end tank design and NO leaks the boost should increase even if you are installing a larger intercooler. If the intercooler is too large you may get more lag as the intercooler will have to fill its huge capacity along with the engine but the PSI should go up or atleast remain what it was.
David Buschur
