Whinning noise after install white rabbit
the whistle start when boost start
at 1 psi
at 1 psi
Originally Posted by mitsuorder
DUDE! I didn't even think about this, the WR makes a high pitched whistle and is particularly noisy when moving air at higer rpms
I have the helix lower IC pipe
there is no gasket in between
Originally Posted by gsujeff55
I guarantee you installed the turbo to lower intercooler pipe gasket upside down.....
10 to 1 odds
10 to 1 odds
the stock tubo didn't have a gaskiet on the outlet to the lower IC pipe
yes I can hear the stock turbo spool when I pay very very close attention
but the white rabbit sounds 10x louder
ok, im talking about where the compressor side of the turbo bolts to the pipe....is that the same thing you are talking about?
Ive never replaced my lower intercooler piping, so i don't know what upgraded ones come with....does the helix one come with a new pipe that bolts directly to the turbo?
yes we are on the same track
I double checked my old turbo and pipe
it just bolts up without gasket
well, there should be a gasket there. If its the stock hard pipe coming off the turbo then there should DEF be a gasket there.
i don't see how helix could make a pipe that wouldn't need a gasket there either(if they even replace that piece).
did you unbolt that pipe from the turbo when you replaced your lower intercooler piping, and bolt it back to the stock turbo...or did you do the lower IC piping with the new turbo?
What psi r u boosting? I had the same noise with another turbo upgrade. I swap to a stiffer spring in my Forge bov then the noise went away. Maybe your bov can't handle the higher boost with the WR.
Originally Posted by superman105
I just swamp the STOCK JDM BOV back to stock
the whistle is still there
so it's not the BOV
so it's not the BOV
My bad, you're right, if it start at 1 psi then maybe some line is leaking or WR's tail is wagging. LOL...
he said it starts making that noise at 1psi, doesn't sound like a faulty BOV to me.
I was wondering the same thing
but the lower Ic never taken off of the Stock turbo until this morning
from factory there is no gasket
