Whinning noise after install white rabbit
Old Jul 12, 2005 | 08:43 AM
  #61
superman105's Avatar
I'm still trying to make a device which will let me do a proper boost leak test
Old Jul 12, 2005 | 08:52 AM
  #62
Chris@nolimitmotors's Avatar
check the pipe that bolts to the turbo. mine leaked for 8 months. take the gasket out and use really good silicon
Old Jul 13, 2005 | 12:05 PM
  #63
EVO8LTW's Avatar
I just made one that works really well. I used a PVC cap that's for 1-1/2" PVC pipe. I drilled and taped a 1/8" npt hole and screwed in a valvestem. And then I used one of the OEM couplers from the stock IC piping to attach it to the turbo inlet (with hose clamps on both sides). Works like a champ for less than $5 in parts (I already had the tap).
Old Jul 13, 2005 | 01:15 PM
  #64
marksae's Avatar
Where did you get your 1/8" NPT valvestem?
Old Jul 13, 2005 | 01:17 PM
  #65
EVO8LTW's Avatar
Local autoparts store (Fairfax Auto Parts). They were on the wall along with air tool stuff. Cost around $2-2.50.
Old Jul 13, 2005 | 04:51 PM
  #66
I did a boost leak test and found out
my helix silicon that's holding the lower IC Pipe had a few cracks in it.
(it's amazing that silicon was NEW !!)
I replaced the silicon today along with a thin layer of RTV on the Gasket to the Turbo outlet
Guess what ! the loud whistle BOOST leak noise is gone !!! Now I can enjoy the cool spooling sound of the white rabbit which is a lot louder than stock turbo !
wow ! can't imagine how loud a boost leak can be.. until it happen to me
tks everyone's help !!!
Old Jul 13, 2005 | 04:53 PM
  #67
unowned's Avatar
Originally Posted by bdking57
and your sure thats not just the sound of a much larger turbo then your used to? I remember hearing a WR at leguna seca and that car was making all kinds of crazy hissing sounds. Sounded awesome
Ditto i was there and have a Video of the Pass that Kent Jordan's car made with the WR turbo, he also is running an AEM intake so the turbo turbine sound is amplified some. It's probably normal.
Old Jul 13, 2005 | 04:59 PM
  #68
marksae's Avatar
Cool. I'm gonna make a new one using a valve stem. Right now have an air tool fitting for my intake leak tester.
The intake leak test never lies!! Glad to hear you found the leak superman105!
Old Jul 13, 2005 | 05:01 PM
  #69
EvoTio's Avatar
I'm glad you were able to troubleshoot your problem. I've had to troubleshoot a few of my own in preparation for Tuning Technologies this Saturday. I'll be looking forward to see your car at the dyno. I'll actually be on right after you. Good Luck.
Old Jul 13, 2005 | 07:48 PM
  #70
EVO8LTW's Avatar
My old tester, which didn't work so well, used an air tool fitting as well. This is much better and you can use a tire pressure gauge to get the system pressurized to the pressure you want without having to check your boost gauge in the car.
BTW, here's what the tester looks like: PIC
Old Jul 13, 2005 | 09:13 PM
  #71
marksae's Avatar
I just went to the local auto parts store and they didn't have that 1/8" NPT valve stem. Oh well.. I just set my air compressor to have 15-20 psi of pressure during my test.
BTW, using that 45 degree elbow at the turbo inlet is a good idea! I currently have a straight on there and I have to push my lower radiator hose out of the way in order to fit my air line on there.
Old Jul 13, 2005 | 09:42 PM
  #72
tks see you at the dyno day !
by the way, I took a lil drive after my boost leak problem
I must say this lil White Rabbit spools ...
ghost911
Oct 12, 2015 07:59 PM
merv414
Mar 6, 2009 02:59 PM
IVERSON3270
15
Jun 1, 2007 12:40 PM
turbodude
15
Apr 19, 2007 07:39 PM
TurboSaleen#163
11
Oct 17, 2005 08:25 PM
