Spark Plug Removal
Old Jul 11, 2005 | 06:36 PM
fastevo03's Avatar
Spark Plug Removal
Anybody having problem removing their spark plug with Sears socket. I tried to remove spark plug with 5/8 spark plug socket and it will not fit into the hole. ANyone has the same problem, does it required a thinner socket?
Old Jul 11, 2005 | 06:37 PM
gsujeff55's Avatar
yes, its a smaller spark plug socket....i wanna say 1/2, but im not 100% sure. I just know i tried the same thing and had to go get the smaller socket
4g63powered's Avatar
I think i used a 13/16 for it. Im betting the correct size is metric though
Old Jul 11, 2005 | 06:38 PM
Sorry I forgot i use the ngk's not the stock ones.
tke_413's Avatar
Guess it's 13/16
Old Jul 11, 2005 | 06:39 PM
gsujeff55's Avatar
stock plugs are NGK...LOL
and they aren't metric
Old Jul 11, 2005 | 06:44 PM
gsujeff55's Avatar
i think the 13/16 is the one thats too big. Either the 5/8 is too small or its the one. I took a quick glance at my tools and those are the only 2 i see. I can't remember, i just knew the one i had was too big
Old Jul 11, 2005 | 06:48 PM
justchil's Avatar
13/16th's is what I've been using.. I'm not sure if it's the exact one but it's worked fine.
Old Jul 11, 2005 | 06:52 PM
GOKOU's Avatar
It's 13/16.
Old Jul 11, 2005 | 06:56 PM
gsujeff55's Avatar
yes, it is. Just tried it.(it was buggin me). I remember now, wheni changed mine, the one i was using wouldn't go onto the spark plug(too small).
the 13/16 barely fits in the hole, but it fits the plug! Sorry for the confusion
Old Jul 11, 2005 | 06:58 PM
justchil's Avatar
I'm not sure what brand mine is but they make one that is a little thinner.. it also has a piece of felt inside with a hole so you can pull your plugs out with it.. pretty nice you just have to be carefull.
Old Jul 11, 2005 | 07:03 PM
fastevo03's Avatar
Thanks for all the info, I will get the right socket
Old Jul 11, 2005 | 07:32 PM
plokivos's Avatar
it's the same size as your wheel bolts but with the rubber spark plug holder inside...
13/16 spark plug socket fits perfect into the spark plug hole. making it air tight for it to go in and out without shaking the plugs.
Old Jul 11, 2005 | 07:36 PM
kmcconn9's Avatar
definaty 13/16, I just changed mine today..I used a snap-on socket if it makes any difference
~Evil_Evooooo~
13
Mar 19, 2010 02:53 AM
omniprobe
Feb 12, 2008 06:16 PM
bluebanana23
Sep 13, 2007 09:31 PM
Ninj0x
Aug 17, 2005 08:38 PM
digdat
Lancer How Tos / Installations
Oct 22, 2004 06:43 AM
