Idle Adjustment
Old Jul 11, 2005 | 11:41 PM
fuzzychi's Avatar
Idle Adjustment
I read a few posts about adjusting idle fo such things as cams or crappy idle. From what I have read, it's on the throttle body near the firewall. But can someone post a picture of the adjustment screw for idle and give me some peace of mind lol ?
Old Jul 12, 2005 | 12:58 PM
fuzzychi's Avatar
bump
Old Jul 12, 2005 | 01:00 PM
BoostWhore's Avatar
its on the top facing upward it looks like a hole you need to put a philps screw driver in it and turn it counter clock wise to move the idle up. sounds like u need a flash though
Old Jul 12, 2005 | 01:03 PM
redevo58's Avatar
I dont have any pics, but if look at the throttle body from the front of the car, at the backend of the TB you will see a round hole that is slightly angled towards the fire wall, in that hole is where the idler screw is at. Just use one of those stubbly/mimi short phillips head screw drivers to change the idle. turning it clockwise will lower your idle turing it counter clcokwise will raise your idle.
Old Jul 12, 2005 | 01:15 PM
Jamie@WORKS's Avatar
Number 4 on the diagram. This adjustment can be taken too far and may be a band-aid for an underlying issue.
DCSilvrEvo's Avatar
Thanks This just helped me because everybody will probally say repost but I read them and they dont help!
Old Jul 12, 2005 | 01:17 PM
Taimur's Avatar
I'm not sure about the Evo's but if you adjust the idle screw doesn't the TPS calibration go off?
And recalibrating it is a complicated process. I know I messed up my Supra like that.
Old Jul 12, 2005 | 01:33 PM
MalibuJack's Avatar
And recalibrating is a complicated process. I know I messed up my supra like that.
Its actually an air bypass, so it shouldn't alter the TPS Position by adjusting it.. But like Jamie said, it isn't the solution to all idle problems and care should be taken to make sure its not another issue you are ending up masking by raising idle speed.
TouringBubble
Oct 10, 2025 11:11 AM
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
bluebyyouEvo03
Oct 26, 2008 06:36 AM
jordo
Mar 22, 2007 09:11 AM
TEJ
Lancer Troubleshooting
Feb 9, 2006 09:30 AM
