question about 10.5 hotside!!!!
hi guys just wanted to know if the 10.5 hotside is a factory piece in the new 05' evos
if so , it must have a part#!? and i can order it thru mitsu?!?
please need a quick answer!!!
thanks
thanks
www.forcedperformance.com has them for a decent price
Part number is MD613524 and list price is $669.04
WORKS has the 10.5 housing for $249: http://www.worksevo.com/store/produc...roducts_id=219
Dyno4mance has the 10.5 hotside with the stud kit for $250
http://www.dyno4mance.com/store/prod...p?sku=METU1002
Check it out!
Check it out!
So Jamie, are you guys selling the older style wastegate hotsides or the newer ones? The picture on your website shows the older style one. Have you guys done any testing to note if there are any performance differences between the two?
We have the older style here now. Others are arriving, but not sure if they're new/old. Once we have both, we'll be better able to compare them. I've read the tech info from Mitsu on the design variation and it looks good on paper. We'll see if it WORKS in the real world
Here you go. Got this from Jamie's NorCalEVO gallery.
From the description, it sounds like the 05 style wastegate helps low end better. I'm guessing that the new wastegate design enables the exhaust path to the turbine wheel to be shaped for better flow.
Originally Posted by GOKOU
Does this mean the wastegate valve needs to be change as well??
