Boost Controller ?
Old Jul 14, 2005 | 06:09 PM
sMIThSUBISHI23's Avatar
Question Boost Controller ?
Installed my Greddy Type S boost controller. Yes there also is a Greddy type s Boost controller. I think its normal but the needle on my boost guage flutters, seems to be boosting fine the needle just does alittle dancing. Normal Right?
Old Jul 14, 2005 | 06:17 PM
Thegame's Avatar
I had the same thing happen to me. Both stock and w/ my hallman. Al told me that usually this happens when the ecu is pulling timing... What boost and ocatane are you running?
Old Jul 14, 2005 | 06:19 PM
I set it at like 19, not really sure cause it flutters, I'm running 93
Old Jul 14, 2005 | 06:25 PM
jshin80's Avatar
how bad is your gauge bouncing? are you talking about needle shaking? or actually bouncing back and forth more than 1 or 2 psi?
usually, mech gauges shakes alittl at max boost and max vac, especially if they use super skinny hard plastic vac+boost line (the white line comes with boost gagues)with that brass fittings. <-- i still don't know how to fit that skinny line with that brass fittings. i just stick with high quality vac hose plug into gauge directly.
try to install a filter or change it to better, thicker vac+boost hose.
if that bothers you big time, time for a electric gauge with stepping motor inside.
every single one of my mech gauges flutters alittle, but it doesn't bother me.
Old Jul 14, 2005 | 06:29 PM
My guage didnt flutter before I installed the BC. There is a filter on the line to. IDK, I guess its not a big deal. Once i get my upper ICP and blow valve I'll get flashed see what happens.
Old Jul 14, 2005 | 06:32 PM
Thegame's Avatar
I'm sure the MBC is allright then, it just might be a gauge thing.
Old Jul 14, 2005 | 07:38 PM
Jakeg97's Avatar
Greddy type s Boost controller?
get a hallman mbc
Old Dec 27, 2008 | 08:43 PM
Neuspeed06's Avatar
My gauge does the same thing, a small needle shake at idle. Have no clue what it is.
