looking for intake kit w/o MAF
Old Jul 15, 2005 | 08:36 AM
Derek888's Avatar
Im looking for a intake kit that doesnt use the stock MAF. I prefer one that sits lower and doesnt bend upwards at high cause im afraid it might hit my upper ic pipe.
DCSilvrEvo's Avatar
Burshur Racing sell em. like 100 bucks or so.
Old Jul 15, 2005 | 08:43 AM
Derek888's Avatar
any other ones? What about AEM short ram?
Old Jul 15, 2005 | 09:00 AM
MalibuJack's Avatar
the buschur pipe adapted very well to running without the MAF, but you need the old style that has the two bends in it, it'll sit low enough for most intercooler pipes.
Dejon Tool also offers a pipe that can be used in a non-maf setup.
On my car, I used the Buschur earlier pipe, I plugged the recirc fitting (since I do swap back to a MAF on occasion for testing) and got a large cylindrical K&N filter to use up the remaining space (I think 5 or 6" by 3.75" or so with a 3" inlet)
Old Jul 15, 2005 | 09:18 AM
Derek888's Avatar
the reason I ask is cause ill be getting the power fc with D jetro. I thought you couldnt use the stock MAF with the unit.
Old Jul 15, 2005 | 09:49 AM
MalibuJack's Avatar
Yah there are two versions of the PowerFC, one is a speed density setup, the other utilizes the stock MAF.. On my car, I have the hardware to take out the stock maf and run a blowthrough sensor (not speed density, but a different type of MAF) but in the process I had to put together a non-maf intake pipe so I reused the pipe I had. In your case, if you want to buy one, you can get a kit with the filter already included from Dejontool, or ask buschur for one of his non-maf versions of the pipe which will have no recirculation fitting and then pick up the K&N filter that he recommends for it (or if he includes one, I don't know)
Old Jul 15, 2005 | 10:30 AM
PPI's Avatar
PPI
good thread, just in time as I am switching to aem and need a pipe with no maf as well. I am going with the ams up i/c pipe, so i need something that will clear that.
I was wondering if anyone has tried to route the air filter back down to get more fresh air from under the car....it just doesn't seem to be sitting in a good spot at all.
But for stock location we have bushur or Dtool..hmmm.
Giuna99
Apr 17, 2016 07:39 PM
tweakdsm
Sep 26, 2009 10:50 AM
PsychDr. HN$
Aug 21, 2008 04:51 PM
turbodreamz21
Feb 6, 2008 08:34 PM
BOOSTEZ
28
May 4, 2005 09:20 AM
