Balance-Shafts Explained
Originally Posted by SaabTuner
If the stock system leaves a large enough margin, there would be no appreciable difference in removing the shafts. But I wonder how the "SMART" system would react to second-order vibrations and if there would be noticably more "noise" in the signal.
Hey, Shiv, if you ever tune someone's car without balance shafts using the new "SMART" system, I'm sure lots of people would be very interested to know the impact of second-order vibrations on knock sensing.
-Adrian
-Adrian
l8r)
That makes me wonder how sensitive the Mitsubishi's stock knock-sensing system is. I'm under the impression Shiv has had some success with making it more sensitive in his "SMART" system and that he has commented on the engine being pretty quiet in stock form
-Adrian
-Adrian
Shiv
Originally Posted by shiv@vishnu
AFAIK, I've only tuned one car without balance shafts. And it was ours. It was a fully built motor (pistons, rods, crank work, etc,.). It was noisey as hell. But to the ear, not necessary to the knock sensor. And i dont think it was noisey due to the balance shaft deletion. It had awful piston slap, most likely due to a poor build. The motor eventually failed (spun bearing). Ever since then, we've always promoted the usage of stock motors. Unless, of course, you find a truly competant engine builder. I hope to test some properly built motors in the future. We'll see...
Shiv
Shiv
The ion-technology is just expensive to license from Saab as they hold the patent. GM brands might have access since GM now owns Saab 100%. But I've not seen it on any other engines myself, yet.
Here's an article by Keith Howard that I transposed a long time ago for discussion on another site.
During the 1980s researchers from the Institut fur Physikalische Elektronik at the Universtiy of Stuttgart published a series of papers about a new form of IC engine ignition system they termed 'breakdown' ignition (aka plasma ignition). Whereas conventional inductive ignition produces an ignition event lasting a couple of milliseconds and a capacitive discharge one lasting perhaps 100 microseconds, the oscillatory spark current in the breakdown ignition system reduced to near zero within 200 nanoseconds. - 10,000 and 500 times faster respectively. Although the breakdown system showed promise in respect of improved lean mixture ignitability, insensitivity to plug fouling and lowered fuel consumption and emissions, it was never employed in production.
Scene change to the late 1980s and a change meeting between two students at MIT: Ed VanDyne, who at the time was in charge of the MIT racing team running Formula Vees, and Stefan Pischinger, who was working on a PhD thesis investigating the lean limit performance of a range of different spark plug designs for Bosch. (Pischinger is now CEO of engineering consultancy FEV in Aachen, Germany, the company founded by his father.) Pischinger was running a single cylinder test engine with a square section cylinder that allowed combustion events to be filmed through its transparent side walls, a mirror arrangement allowing the flame kernel to be viewed from two directions at right angles so that flame growth could be visualized in three dimensions.
"Every once in a while over a six month period he'd come in at the same time we were there and we'd watch one of his movies," recalls VanDyne. "There was one night when he had a dramatically different spark plug, from the look of it in the movie, and it had dramatically different combustion results. The frame where the arc occurred was very bright compared to all the other movies I'd seen, and the flame growth was remarkable. One frame there was nothing, next frame the flame kernel was already growing fast enough that two or three frames later it was off the screen. In the other movies there would be 10 to 12 frames before the flame even grew to the point where it engulfed the spark plug. This plug did that by the second frame after the spark!"
"The growth was so dramatic that I decided to find out more about what Stefan was doing. It turned out that he had built capacitance into the spark plug to act as an energy store. When the plug fired, the capacitor dumped a very high surge current across the gap that made a very hot spark." (Nology's aftermarket HotWires ignition leads exploit this same idea by placing an external capacitor as close as possible to the spark plug, which discharged through the gap once the breakdown voltage has been achieved.)"
The design of the spark plug itself was a vital factor too. Whereas a conventional J-gap plug has an earth electrode which curves over the centre electrode, blocking flame kernel growth to some degree (sometimes considered a benefit as it shields the developing kernel from mixture turbulence), the spark plug that had given such an impressive account of itself on the combustion movie was a projected surface gap type (Figure 1)
which relies on electrical conduction across the surface of the ceramic insulator to one or more short ground electrodes arrayed around it. [Note: there are actually four or more short ground electrodes on the plug, not just one like shown in figure 1]
To VanDyne's surprise, Stefan Pischinger didn't consider that the faster kernel growth provided y the combination of breakdown ignition and a surface gap plug was of practical significance. "I looked into it," says VanDyne "and realized that sure, the breakdown ignition system used ahead of the spark plug wasn't practical. What you needed to be able to do was turn that high energy pulse on and off at will. So I went over to the MIT strobe light lab and talked to the head technician. He and I went over how a strobe light circuit worked and I asked him if I could combine an ignition circuit with a strobe circuit. He said he didn't see why not. So in 1990, two 1940s patents - capacitive discharge ignition and a strobe light were combined to create something patentable in its own right (Figure 2). I went to the MIT technology licensing office who offered to file the patents and license them back to me." And so Adrenaline Research Inc was born as a spin-off company from MIT, initially by Ed VanDyne and two colleagues.
The short high-current pulse used in the Pischinger ignition lasted 100-500 nanoseconds. Out high-current pulse from the strobe circuit, has a long duration of about three microseconds, with a peak current of 100-300 amps. So the pulse train is slightly different but both create a bright plasma discharge. In our system we have about 100 microsecond duration overall because we still have a capacitive discharge ignition firing the coil. As soon as the gap has broken down it provides the conductive path for the high power from the strobe circuit to be dumped in three microseconds, then the low current, about 500 milliamps continues to flow from the coil for another 100 microseconds. The plasma discharge on the project surface gap plug promotes faster flame kernel development because the high current on the insulator surface dissipates 4 times as much electrical heat energy into the combustible mixture. The best analogy is that of an arc welder – when you turn up the current, you turn up the heat.
Although this short duration high energy spark has direct benefits in respect of improved lean limit performance and increased engine power, this isn’t what justifies the name Smartfire for the Adrenaline ignition system. The indirect benefit of this brief ignition even is that it facilitates effective monitoring of the ionization within the cylinder, which allows misfire and knock detection to be performed more reliably than with the conventional methods and cylinder by cylinder. Real time closed loop control ignition timing and fuelling is also made possible, again on a bespoke basis of each cylinder. These capabilities are what make VanDyne’s ignition technology ‘smart’.
Ionisation occurs within the combustion process when free radicals, intermediate chemical species are formed which carry an electrical charge. These provide a comductive path across the spark gap during the combustion even, the conductivity of which is related to the progress of combustion. In the Smartfire circuit this is monitored by placing a relatively low voltage (100-300 volts) across the secondary capacitor (which is also used, at higher voltage, to store charge for the high energy plasma ignition) and measuring the gap current via the resistor.
Exactly how closely the combustion and ionization are related you can judge from Figure 3, which superimposes graphs of cylinder pressure and the equivalent ionization current (monitored as a voltage across R). There are two peaks in the ionisation curve, the first of which occurs shortly after the spark. This is related to the combustion process when the flame touches the tip of the plug. A second smaller peak in the ionisation curve occurs later and is closely related to the temperature changes within the cylinder. As a result, the second peak of the ionisation curve occurs at the same crank angle position, on average, as peak cylinder pressure. This indirect determination of where peak cylinder pressure occurs is what allows Smartfire to execute closed loop, cylinder by cylinder control of fuelling and ignition timing. Detection of misfire is almost trivially simple: the ionisation signal simply ‘flatlines’.
In fact the ionisation tracks temperature within the cylinder so closely that if the cylinder is knocking (figure 4), telltale fluctuations are clearly visible in the ionisation signal at around 6 kHz (or sometimes the second harmonic). This oscillation can be detected by digital signal processing within Smartfire, which flags when knock is detected. Again, this is achieved on a cylinder by cylinder basis.
It’s worth a little break for a bit of a historical note: Saab used a combination of capacitive ignition and ionisation monitoring on its road cars some years ago but has begun to phase this out and is in the process of reverting to inductive ignition. The overriding need in modern road cars is to prevent misfire, both to protect the catalytic converter from damage and enable the vehicle to pass increasingly stringent emissions tests. In this respect, inductive ignition is better than conventional capacitive discharge – a shortfall that Smartfire makes up though its addition of the strobe circuit.
Catalyst protection is irrelevant in most racing formulae, of course, but the Smartfire system’s ability to detect misfire and knock and to provide closed loop adjustment of ignition and fuelling for each cylinder, make it just as relevant on the race circuit as the street. “I never thought misfire would remotely be an issue in racing engines, but it turns out ir really is,” says VanDyne. “I’m hearing more and more from racecar builders that they’re having full load misfiring because of the they’re now fuelling the engines.
“I can’t describe some of the proprietary fuelling methods but it’s public knowledge that Audi has used its FSI (Fuel Stratified Injection) technology at Le Mans. Others are trying to follow suit but it’s a very difficult thing to achieve. FSI was originally designed for low emissions and high fuel economy in street cars, but its fuel economy advantage can be significant in racing too. Audi won the first time at Le Mans without the technology. When they came back the second year, the reason they went a whole lap further between pit stops was the fuel economy advantage of the FSI. So Audi’s dominance in 2001 and 2002 was partly due to the fuelling technology. But these advanced fuelling methods have the disadvantage that they can cause misfires under conditions where in the past, racecars didn’t misfire. Where fuelling issue are becoming critical, normal ignition systems aren’t keeping up. That’s where we have an advantage. “
“At these high engine speeds we don’t even attempt misfire prevention. It’s not an issue that the misfire comes out of the exhaust, whereas in a road car it is – there can be conditions where we may do misfire prevention (a second spark) 50 degrees after the first ignition just to attempt to prevent that slug of fuel and air getting to the catalyst. For racecar applications misfire detection is useful, at least as a diagnostic tool. We have performed misfire detection up to 18,000rpm, so we really can do it fast enough for today’s high speed racing engines.”
“We wouldn’t necessarily use high energy ignition in a racecar application, although some will like the extra power of the faster flame kernel development. We’ve done experiments at high engine speeds which show that, even though there’s a rich mixture, you can retard the timing by 4 to 6 degrees and get, typically, a 0.5 to 1 percent increase in power. The later you start the burn before TDC the less work you lose pushing against the piston on the upstroke. That’s an advantage before you do any ionisation monitoring.”
“The potential problem is, at full load the high energy discharge will erode the spark plugs about five times faster than normal. I don’t like some spark plug manufacturer’s because they use inexpensive materials, not even Inconel, in the racing spark plugs. We need Inconel to get the durability our high energy sparks require, otherwise even over a race distance the plug can be over-eroded. Fortunately some of the manufacturers make their 10mm F1 plugs with Inconel electrodes so we can avoid problems with plug life. Also we have an incredibly good machinist close by who can rework spark plugs for us. We’ve shown horsepower improvement by cutting the side electrodes off a Bosch plug and inserting Inconel pins to turn it into a surface gap plug.”
To date Smartfire has only been used in the dyno cells of racing engine manufacturers, but an on-car system is no on the horizon as a result of the licensing deal Adrenaline has signed with Motorola to develop the technology for road car use.
“We had hoped to get a racing partner to fund making an in-car hardened system. Teams liked the concept but even in F1 they are very conservative. They want it handed to them in the final form that goes in the racecar. They certainly don’t want to pay us to develop it. But together with Motorola we are developing the system for the automotive world and the plan is to use this module as the first generation in-car racing system. It will be subject to much more rigorous testing than we’ve been able to put our existing box through, and it will be more compact. Our current controller measures about 3 x 5 x 5 inches and is not ideal for a high vibration environment, so it’s not really suitable for fitting to a racecar. We have to get it out quickly and with all the features needed for dyno test cells, so we sell this as the instrumentation product and expect to make the in-car version together with Motorola."
“OEM production is slated to start in time for the OBD2 100 percent misfire standard that comes effective in California in 2005. So we have about 15-18 months development time remaining for that. For the racecar people the unit could be available earlier because we will have pre-production prototypes this fall. They become, as far as I’m concerned, in-car racing test systems. “
Smartfire’s ionisation monitoring will be put to work from the outset, initially for knock detection. “The first customer we expect to test with primarily needs the knock detection. They will remove their block transducer and use our system as the input to their knock algorithms. Currently they get significant ignition retard -8-10degrees because the transducers pick up valvetrain and other noises. They know the engine can knock, and they’ve calibrated it fairly aggressively, they also know that if it does knock it’s only on one or two cylinders. Because all the cylinders are retarded when knock is detected, their current method is really not working. Whereas we can do knock detection on a cylinder by cylinder basis, we won’t flag all the cylinders unless all the cylinders are knocking. They think they’ll gain a significant horsepower advantage from being able to retard the cylinders individually.”
The next stage – real time closed loop control of ignition timing and fuelling based on the ionisation data – is already feasible. “We have a CAN bus on which we can output critical information that allows closed loop tuning. The algorithm is already written and we’ve establishes that the system works with many different types of combustion chamber. Determining the ideal ignition timing for each cylinder is a no brainer because the ionisation signal identifies when peak cylinder pressure is developed. It is the ideal air fuel ratio that takes a bit more of an algorithm (figure 5).
”The power advantage is very variable between different engines – it could be as little as less than 0.5 percent, but some F1 engine manufacturers can have a 3 percent output variation engine to engine. What they are not able to do is diagnose why this occurs when they build them to such exacting tolerances. We are looking to show them where the deficiency lies by being able to do a tune up on each cylinder. We think our system has the capability to null out that 3 percent variation, or at least reduce it to one percent. So it may not raise the power of the best engines at all but it could take the worst engines up two percent, so they don’t have to scrap them. Or they could use our system to diagnose the problem and fix it.”
“The big value, as in a street car, is that we can measure combustion effects without intruding on the cylinder in any new way – our technology is completely non-invasive. You can plug Smartfire on to any race engine and monitor its combustion characteristics whereas an instrumented engine, with in-cylinder pressure sensors, could never be fitted in a racecar. That’s the great benefit of this system.”
Thanks for the links on triac and thyristors. I haven't read the article yet.
This is exactly the part that is new to me.
Surely there is someone you can write to at SAE or an institution that has done lots of this type of research and discuss this with them? How can so few know about this or want to follow up on it is what I truly do not understand. If the NACA article can reach an enthusiast forum, surely there are hundreds, possibly thousands of people in the scientific community that know about it too.
Weekend!
Spontaneous and homogenous auto-ignition of the end gas does not produce the "ring" associated with detonation.
I thought the same thing. "Hotrod" over at nasioc pointed it out to me about a year ago. It blew my mind. Several people tried to debunk NACA's work in a discussion at nasioc. But in EVERY SAE paper anyone there (including several SAE engineers) could find the first lines read "Knock is generally assumed to be" ... and none of them ... not ONE actually asked if knock was before or after the flame-front. Only NACA did research on that to anyone's knowledge. I think it is very likely that this "general assumption" is self-defeating; no-one knows what knock is with absolute certainty yet and I think that assumption is why. Ironically the assumption by so many people may be the reason they are forced to make that assumption in the first place.
Interesting note: I actually met an engineer for NASA not long back. (His desk still said "NACA" on it.) And I talked with him briefly about this. He agrees that it's ironic so many people are making a living off trying to tace down information which was allready found 60 years ago through government programs with almost unlimited budgets. NACA was doing ultraviolet spectroscopy on the gasses, schliren films, and standard photos. (Detonation is a purple flame/flash, btw.) NACA used an engine which could be supplied with any pressure or temperature air they wanted at any air/fuel ratio and they used stellite mirrors on the pistons and loooads of other really cool stuff. And no one knows about it!!
Weekend!
Great article.
Saab patented Ion-sensing in combination with Direct-ignition with Mecel AB back in 1985. It may have only been patented in Sweden since this was before GM had any stake in the company. The new Trionic 8 engines (new 9-3's) use the Inductive discharge, but the ion-sensor is still present AFAIK. They still have misfire detection, pre-ignition detection and no "traditional" knock sensors.
That ignition system sounds really trick. It would be nice to have a shorter rapid burn angle. But if this device only shortens the flame development angle, then it will only be especially usefull for increased lean and rich burn limits. Increased lean-burn would be very nice though for mileage reasons obviously. Obviously then, Saab either doesn't still hold patent rights, someone is paying royalties, or they don't care if anyone else uses the system. That means the possibility of using it on an Evo, which would be nice! It's worth looking into for sure.
Also, in a combustion-bomb test conducted in Japan, the researchers found that the second-peak disappeared if the walls of the bomb (away from the plug itself) were not connected to the negative source on the circuit. (grounded) So, the second peak represents the point at which the flame-wave reaches maximum contact with the cyllinder walls, piston, and combustion chamber.
By matching two gaussian curves to the ion-signal (after the coil-ring) you can deduce the Peak Pressure Position from the second of the two gaussian curves. The shape and magnitude of the second gaussian curve also closely represent the burn-rates. It's a great combustion analysis tool!
-Adrian
-Adrian
Nobody at the SAE will listen to you unless you have a PhD in something. They won't even read it, or respond to it, when I send it to them! I can't say I blame them, given the number of "eccentric" people making strange claims like this. But I think they're shooting themselves in the foot by ignoring it this time, but apparently they have very good aim.When I visit Berkley in a few weeks I'm going to run it by their engineering and physics professors to see what they think.
I'd actually be happy if they somehow managed to prove it wrong; I just can't stand when they ignore it entirely. I've only had one engineer try to refute it and he couldn't find a single paper that didn't start out "knock is generally assumed to be...".
Oh well. Weekend's coming!!
-Adrian
Originally Posted by SuperHatch
I always head about the 1.7 rod ratio being the best, but never truely understood why, now I do! That's awesome....
So in your opinion, even on a built motor/stroker motor, having the factory balance shafts there and not tuned to the geometry of the stroker motor is still better than not having them there at all?
- Steve
- Steve
If you were to calculate shake forces for a similar volumetric flows between a stock engine, and a stroker engine, I am sure you will find the stroker engine (at the same volumetric flow, lower RPM) has less shake.
There are other benefits to running lower RPM too. Do a search on the posts I've made in the past. There was a fairly recent thread I think.. about a month ago.
Very true. I don't mean to turn people off to the idea of stroker motors, or to make them think they absolutely positively need balance shafts. It's ok to stroke it, and to not have balance shafts. I just wanted to make sure people knew exactly why they were the way they are in the first place so they can make an educated decision.
Saab went with shorter rods for a while to a 1.64:1 ratio, but, because they are generally regarded as luxury cars, they ended up back at 1.7:1 for the newer ones because they could achieve the same displacement with less vibration by using slightly shorter pistons. That weakened the pistons, but it hasn't been a problem on cars running less than 300 hp, so no biggie for most Saabers. (The old pistons were fine to well over 400 hp.)
How short is the rod ratio on a stroker motor for the Evo anyway and what is the stock rod ratio? (Pardon my Evo-noobness.)
-Adrian
-Adrian
no problem, just was letting superhatch know of some more considerations.
I cannot find stock piston compression height anywhere, neither can I find block height as I want it (crankshaft centerline to deck). 11.4" is the official block height, but it is skewed by the fact that the 4G63 crankshaft sits recessed and the 11.4" measurement is from the pan rails to the deck. But anyway, assuming a typical 1.25" compression height FI piston..
Stock 2.0L (1997cc) - 1.70
2.4L (2370cc) stroker - 1.40
1) Mean piston speed on the 2.0 is higher by 2%
2) Peak piston acceleration on the 2.0 is higher by 16% at TDC, 34% at BDC.
3) Not only is the engine experiencing these higher loads, but it is experiencing them at a rate faster by 18% . Finite cycle life of all components is being used up quicker.
Sorry Shaun,
Following the thread with interest. Just for clarification sake, I recall there being several configurations for a stroker kit for and evo even with the same displacement. i.e. diff cranks or at least diff rods lengths. Which basic setup were you referring to?
Regards
Ean
Good info. Intersting points.
Regards
Ean
I really hate to bring down the level of the conversation here but I have a question about this and you guys seem like the people to ask. Please keep in mind that I have a general understanding about this and an interest in engines and physics (but only studied physics until I finished high school) but that is about all. I would probably need a week or two to read and understand all the information you've shown so far and a bit of extra research too.
So the question: You are talking about removing the balance shafts to rev higher than stock, I think I saw a mention of about 7500rpm in there somewhere, but what about a lot of the Japanese MIVEC, VTEC, VVT, etc. engines that rev to about 8200 to 8500rpm standard or the S2000 engine that goes to 9000rpm? Do these engines still have balance shafts? What about engines like the 1980's BMW M3 (E30) that were sometimes reved to 10,000rpm in race form, or were the balance shafts removed for racing?
Sorry again. If you would like me to take this discussion somewhere else please let me know, or if this has been answered and I missed it I am also sorry.
I have been a bit busy studying at University for the last 3 years to hav time to research other things but now that I have finished I would definately like to look into stuff like this, I think I probably should have taken a physic/science/engineering type degree instead of I.T.
Aston
Aston
What is new to me is all this talk of what "knock" really is and I'm enjoying it very much.
- Steve
P.S. - Can either of you recommend a good college level textbook, or some technical literature regarding engine design? I've read many "Barnes & Noble" type books on engine design, but they only tell you what they think is good as far as geometries and never get into the math behind it.
Originally Posted by asidbyrne
Sorry Shaun,
Regards
Ean
Regards
Ean
Cheers!
