Headers vs. Ported exhaust manifold
Originally Posted by eling99
with the works o2 housing, you can still bolt on any dp, right?
is the turbine housing same as the 10.5 hotside?
since i have an 05, that means i actually have to find a 10.5 hotside or can port and coat mine?
Originally Posted by AlwaysinBoost
that housing is pimp. Port that sucker out, high temp coat it and call it a day.
Does anyone know what DP's that will fit? I have a megan...
which is why i say get the dnp cuz it's lighter and as long as yer usin' yer stock mani nothing is gonna break. no need to port, just coat it... and it costs half as much as that thing, and you can't exactly say dnp is bad quality.
Originally Posted by trinydex
you can get it ported and coated no prob... might wanna do a core exchange type so you don't have too much downtime, i believe buschur offers it.
thanx a lot!!!
you know while you have it all out you should port and polish and coat everything so you don't have to pull the radiator too many times. i suggest doing everything i said above at the same time, unless you wanna do before and after stuff. but honestly... it's not worth it, haters will always be haters, dynos are the bane of my existence. just know that your car is fast and efficient and you don't have to prove jack**** to anyone else.
I completly forgot that Megan Racing sells a 3" o2 house that will bolt up perfectly to my DP. I think its around $180 or so. That along with a ported and coated stock manifold like the one in the thread above and a 10.5 hotside is the way I am going to go. efficent and reliable.
The megan racing is a 2.75 or a 2.5 inch, not a full 3. You don't really need to port the works housing. Coating it is fine. Also, the Turbo XS pipe seemed similar to the Works. Can't speak about any others though since I haven't seen them.
It seems the Helix, Megan, SS-autochrome, and Pro-1 02 housings are EXACTLY the same thing, anyone else notice this?
You think the Works 02 housing will fit with the TXS DP?
All Headers are not the same. SS Autochrome has terrible fitment issues and crack with ease. I have yet to see a DNP crack and the one i had never cracked and i ran it for about a years time. Would still have it if i didn't got with a full garrett setup. DNP also comes with braces already welded on. Remember, you get exactly what you pay for with aftermarket manifolds.
