Do I really need a flash??
Old Jul 19, 2005 | 02:22 PM
  #31
PVD04's Avatar
Although it is possible to tune it with the SAFC, there is more power to be had with a mail-in flash fine-tuned with an SAFC. I initially had my car tuned with just the SAFC, but then got a mail-in flash over that and noticed a huge increase in midrange power (3500-5500 RPM). The top end remained about the same. I did log a few runs to determine my times from 40-60 mph in 3rd gear and if I recall correctly I picked up 2 or 3 tenths of a second with the flash (~2.5 seconds down to 2.2). Hope this helps with your decision.
-Paul
Old Jul 19, 2005 | 02:24 PM
  #32
PVD04's Avatar
The S-AFC isn't the logging device, it's just the tuning device. I log timing with my pocketlogger, and I adjust my S-AFC settings according to where I see knock (dips or flat spots in the timing curve).
Jeff, yes, if I run more than 21psi on pump, then the ECU pulls timing automatically if I'm too lean. I add fuel and adjust the boost down if I have to in that case, but I try to tune it to 20-21psi on 93oct so that my timing curve is just about linearly-increasing through the power band up to a max of 19-20 above 7k rpm. With a mix of 104/93oct, I turn the boost to 22-23 and lean out the S-AFC en route to an even nicer timing curve that maxes at 21 at 7500 in 4th. I did 5-6 straight runs in the 12.22-12.34 range at this setting in 80 degree weather with all the logs being almost 100% identical. No knock and nothing too lean, but definitely aggressive.
Another thing to remember is that he has an 03, not an 05. The 03 factory tune has less aggressive timing than the 05 therefore reducing the potential gains with an SAFC alone. Your results with the SAFC have been quite impressive, but I'm not sure that they are possible with an 03.
-Paul
Old Jul 19, 2005 | 02:30 PM
  #33
Warrtalon's Avatar
I did not know this had been confirmed. Do we have confirmation of this? I'm not arguing against it, but I just hadn't seen any empirical data.
I agree and stated as such previously. If he's willing to spend the extra money, then this can be achieved, but I still don't think it solves his "problem." If his car isn't running well and already pulling over 300whp (even on 91), then his SAFC is not tuned correctly (if at all). He should verify this before buying bandaids to fix it. Plus, if it's not properly tuned now, it won't get properly tuned after the flash either...
Old Jul 19, 2005 | 02:31 PM
  #34
mrmefodman's Avatar
since we're talking about such things what do u tune for when you are tuning for the intake. I thought the MAF would account for more air??? I have heard numerous times that intakes are worthless unless they get tuned for.
Old Jul 19, 2005 | 02:36 PM
  #35
Warrtalon's Avatar
Keep to the topic. Also, your question has been asked thousands of times (search).
Old Jul 19, 2005 | 02:48 PM
  #36
Thegame's Avatar
If you plan on doing more mods soon, do a lot of racing, etc, I would just get the proper devices and tune your SAFC. Even if you have to get help from a professional, I would do it. If you plan on leaving everything as is for the time being, I would get a custom tune from Al or TT, etc. The thing that I really want to do is tune my own car. Since I've installed all the parts on my car all by myself, I wanted to tune it myself too. This could be risky, but in the end you will have a car that you personally were able to build all by yourself. I have a lot of respect for those people, not to say getting some help is bad, I just think it would be nice to have everything done yourself.
Old Jul 19, 2005 | 02:58 PM
  #37
moogle's Avatar
Originally Posted by rubelcon
DO NOT FLASH!!!
listen to this guy!!! Get an SAFC and get it tune from some dsm peepz or let them teach you. Dr gray from socalevo got 348 hp/ 345 tq w/a safc http://www.socalevo.net/forums/viewtopic.php?t=9180.
if u R going for a flash read my sig, but I prefer safc. I got 284hp/286tq on my 05 with just a catback, gut cat, and safe tune w/a safc.
Old Jul 19, 2005 | 03:02 PM
  #38
JoeA's Avatar
Nice numbers for those mods moogle I might look into it I have an 05 as well
Old Jul 19, 2005 | 03:10 PM
  #39
Thegame's Avatar
A little off topic, but not really... Moogle, what did dynoflash do to your car that makes you not like them? I'm sure a lot of us would like to know.
Old Jul 19, 2005 | 04:13 PM
  #40
EVILutionVIII's Avatar
Veteran: Air Force
OK, so numerous things come to mind after reading this thread:
1: Although it may be in my mind, it's possible my cams were installed incorrectly. I say this because after the install, I noticed some gains up top but every once and a while, the car will run like complete s$%# while trying to accelerate (feels like it's chocking) and once I let off the gas and give it another go, it seems to run fine. However, lately it's been having this symptom more often than not?!?
2: I've done my homework, which is the reason why I bought the AFC in the first place. Now I don't have any type of data logger which is why I haven't had the chance to do too much. The last thing I need is to hear my engine falling apart. But I've read that an AFC on top of a flash can't do any harm at all.
3: Since TT isn't too far from Lancaster, I'll be making the trip down there to have the car's issues diagnosed and the ECU flashed.
I'm hoping my problem is due to lack of proper tuning and not incorrectly installed cams. But nonetheless, I'll do a pre-flash/tune dyno run followed by a flashed/tuned run to see how big a difference a good tune makes.
Thanks for all the help fellas.
Old Jul 19, 2005 | 04:45 PM
  #41
DynoFlash's Avatar
To the guy who started this thread - if you want to try the Dyno Flash and see how it works you can try it risk free and report back your results. If you are not fully 100% satisfied I wont charge you a dime and I'll flash you back to stock.
You have nothing to loose - give it a try and see how it works first hand.
Old Jul 19, 2005 | 04:47 PM
  #42
DynoFlash's Avatar
-Paul
This is true becuase cars run with the SAFC typically pull loads of ignition timing down low. The stock timing tables become very advanced when you are pulling out significant percentages of load on the maf signal. In many cases they wind up with negative ignition timing or zero degrees advanced. This is why many SAFC dyno sheets have 20 - 30 less tq than whp, unlike the flashed dyno sheets which have equal tq or slightly more.
In addition - the flash can access boost control in the stock ecu, fuel cut, rev limiter and other critical features such as the dual fuel and igition maps in the ecu.
Witha safc as the maps switch in the ecu your tune is consantly going on and off - its a set percentage off of a table which switches back and forth between high octane and low octane maps which are changing depending on operational conditions the ecu is recording.
Old Jul 19, 2005 | 05:15 PM
  #43
KILTERMAN's Avatar
CANT BEAT THAT!!
Old Jul 19, 2005 | 05:22 PM
  #44
DynoFlash's Avatar
Originally Posted by KILTERMAN
CANT BEAT THAT!!
I have a 2 week test drive money back gurantee with every flash. I have very few people who don't want to keep the flash, probably one or two out of 300.
Old Jul 19, 2005 | 07:11 PM
  #45
Veteran: Air Force
Sounds good, but I still need to make sure my only problem is not being tuned.
