Boost leak @ TB
Old Jul 19, 2005 | 03:33 PM
mooreboost's Avatar
Boost leak @ TB
I have a boost leak somewhere around my TB but I cant seem to locate it. Has anyone else had this issue? Where exactly was the leak?
Old Jul 19, 2005 | 03:39 PM
titaniumkingpin's Avatar
i heard that its normal to leak a little from the TB.
Old Jul 19, 2005 | 04:26 PM
mooreboost's Avatar
I doubt it.
Old Jul 19, 2005 | 04:28 PM
https://www.evolutionm.net/forums/sh...d.php?t=148717
Old Jul 19, 2005 | 06:00 PM
VTECH8TR's Avatar
It's not normal. Your seals on your throttlebody are bad. Its a PITA to fix, the easiest way is to find another throttlebody to replace it with.
Old Jul 19, 2005 | 06:06 PM
Ultimate CC's Avatar
Yea my friends car is running real low on power and we did a boost leak and found that it leaked quite a bit from the TB. When we figure out more we will post what we find.
Dan
Old Jul 19, 2005 | 07:43 PM
mooreboost's Avatar
**** Luis that's not good news.
I may come up and have you look it over before I order a new one.
Old Jul 20, 2005 | 06:36 PM
mooreboost's Avatar
Any other opinions?
Old Jul 20, 2005 | 06:48 PM
VTECH8TR's Avatar
Dan
Good luck as this is no easy fix. You have to take the whole throttlebody apart and pray it doesnt stick with new orings. I have attempted this on several cars with some success. Garrett i got you taken care off : ).
Old Jul 20, 2005 | 06:54 PM
Quickshifter's Avatar
how do you know its at the throttle body???
Old Jul 20, 2005 | 06:55 PM
mooreboost's Avatar
I ran a boost leak test, and it started hissing near the TB, and eventually it turned into a really loud high pitched whine.
Old Jul 20, 2005 | 06:57 PM
VTECH8TR's Avatar
You can hear it pretty easy, you can also mis some soap and water in a spray bottle and spray it to see where it bubbles at .
Old Jul 20, 2005 | 07:01 PM
mooreboost's Avatar
Luis, is there any other possibility or is it definitely the issue you're thinking of?
Old Jul 21, 2005 | 12:49 PM
mooreboost's Avatar
Bump.
Old Jul 21, 2005 | 01:17 PM
marksae's Avatar
I would try to avoid using o-rings on the throttle body shaft if possible. There's a potential of the throttle body getting stuck, which can be pretty dangerous. I've used these seals on my old GSX w/ good success. They may or may not fit the EVO.
http://www.machv.com/throtbodseal.html
