My evo is boostin early with Hallman manual boost controller
Old Jul 26, 2005 | 08:49 PM
awdjunkies's Avatar
exactly.. Its like Viagra to the car.. lol
Old Jul 26, 2005 | 08:50 PM
03silverevo8's Avatar
so that means i have to get it tuned? i cant just turn the boost down?
Old Jul 26, 2005 | 08:57 PM
KillaSweep's Avatar
just run around 19-20 psi and you should be alright.....watch out for the winter though....the colder it gets the highers you're boost will spike. I had this issue myself hitting the boost cut on very cold days.
Depending on the amount of mods you get and the boost you are running it might be a good idea to get a Walboro 255 upgraded fuel pump...this with ensure that you are not leaning out your fuel mixture too much at higher RPMs. Goodluck!
Old Jul 26, 2005 | 09:05 PM
donutmonkey's Avatar
Turning the MBC down is safer than turning it up if you don't know what's going on with the AF ratio. An AF gauge is a good way to see what's up. Lean is bad. Very bad.
Read This Book
Old Jul 26, 2005 | 09:07 PM
well i really thank you guys for the help
Old Jul 26, 2005 | 09:11 PM
KillaSweep's Avatar
not a problem....just keep reading these forums and what not.....you'll be amazed how fast things start making sense and tie together....this forum is reall great....i browse through it every day
Old Jul 26, 2005 | 09:16 PM
Mr. Slappy's Avatar
Ok I'll be nice. Meet some import guys around you and know their stuff. Listen and learn as much as you can.
Old Jul 26, 2005 | 09:20 PM
Spec'd's Avatar
I was nice from the beginning.
Old Jul 26, 2005 | 09:21 PM
plokivos's Avatar
get the fuel pump at **************** D.
Old Jul 26, 2005 | 09:32 PM
bbyevo8u's Avatar
i don't have a A/F ratio gauge and i'm running a TI catback and a GFB bov do you think i might be running lean at all in any part of the RPM's??
can you guys give me some info about this
Old Jul 26, 2005 | 09:46 PM
Spec'd's Avatar
It is possible that you could be running lean.
There's a few ways to deal with that. The SAFC 2 is one good tool for
adjusting your a/f ratios, with a wide band sensor installed, a datalogger
you can do a lot.
There's tons of information about electronic engine management. The more
you can gain understanding the better your Evo will run.
I'm learning myself... and learn more as time goes on.
This forum is a library of information.
Old Jul 26, 2005 | 09:58 PM
Warrtalon's Avatar
No.
bbyevo8u's Avatar
thanks spec'd
does anyone else have the same set up as me that was thinking the same thing?
Old Jul 26, 2005 | 10:00 PM
plokivos's Avatar
go get a dyno for sure with tail snifer afr readin...
stock cat would make it... lean? or rich? on the reading? i forgot.
Old Jul 26, 2005 | 10:01 PM
Warrtalon's Avatar
thanks spec'd
A cat-back and a BOV is not a setup. You are not running lean. Evos run crazy rich above 5k rpm under boost.
