My evo is boostin early with Hallman manual boost controller
A cat-back and a BOV is not a setup. You are not running lean. Evos run crazy rich above 5k rpm under boost.
Wouldn't that lean it out some ?
Originally Posted by bbyevo8u
thanks spec'd
does anyone else have the same set up as me that was thinking the same thing?
Originally Posted by Spec'd
Yea but bbyevo8u has a Aem short ram intake also.
Originally Posted by MYEVO8U
such hatred these days.... Damn you don't have to bash the poor guy... This is probably the first turbo car he has owned much less with a boost controller.
Ok let me try to explain this to you... Your car was boosting pretty good Stock.. You add the exhaust and intake= loose a couple psi, but yopu don't notice it from the power adition. Now with the MBC you have added the boost the car wants. And also with a boost controller the Boost will come on much quicker and last longer..... Spooling to full boost at higher RPM's is called turbo lag= not good for power. the sooner to full boost the better.
Have fun.... its a good thing.
not even edited posts. maybe they were deleted? Or they were from another thread?
just remember one thing... dont feel safe because some bozo says "its fine", that bozo wont be paying for your repair if you melt your pistons. without a tune, get a fuel pump if you wanna keep the boost at 19 psi. even then dont be going WOT at redline for long durations, your EGT(exhaust gas temp) will rocket up and you will at minimum, melt your rear bumper. to sum it up, there is NO substitute for a flash or piggyback
