trany rattle noise, please advise !!!
Old Nov 9, 2005 | 08:30 PM
  #31
93civEJ1's Avatar
i had it both stock clutch and the ACT...my tranny just started bad leak all of a sudden, and dealer thinks it maybe input shaft seal went out.
Old Nov 9, 2005 | 08:31 PM
  #32
04 rs's Avatar
anyone know where to get any info about the tsb??? also dealers have to perform the tsb even if the car is moddified correct??
Old Nov 9, 2005 | 09:57 PM
  #33
EVSEVO8's Avatar
The dealer does not to perform the tsb if the car is modified. TSB stands technician service bulliton. This is not a recall. Just info for the tech. to use while diagnosing a problem with the same type of sypmtom. I had my trans rebuilt at 13K. For worn out input and out put shaft bearings. Was pretty noisy. If you feel you have the same problem. Drain your trans fluid in a clean container to check for metal flake if the fluid. Mine had lots off metal in the fluid.
Old Nov 9, 2005 | 10:06 PM
  #34
JSYEVO's Avatar
i think the rattling noise is the throw out bearing and from what ive heard, its ALWAYS going to rattle
Old Nov 10, 2005 | 04:53 AM
  #35
93civEJ1's Avatar
i think youre wrong.
ive heard rattle, and then ive heard RATTLE.
