Alkohol Flash-running w/out alcohol
Old Jul 28, 2005 | 10:22 AM
3deep's Avatar
How many of you are running a alkohol flash and how does the car run when not on alkohol.What if you are too lazy or busy to fill the tank.I know you have to reduce boost but how does the car run with all that timing at reduced boost.Any regrets for not getting a piggyback or standalone ems.
Old Jul 28, 2005 | 10:41 AM
Kronik's Avatar
Far as I know the car will run the same -- you just don't want to boost over 21 lbs.
Old Jul 28, 2005 | 10:45 AM
gsujeff55's Avatar
it will pull timing out, a pretty good amount probably.
alky kits aren't for everyone....and you sound like the prime candidate for NOT getting a kit.
Old Jul 28, 2005 | 10:54 AM
EvilDylan's Avatar
bad bad idea if you are flashed for alcohol and you arent running any.
Old Jul 28, 2005 | 10:55 AM
Ev0ikon's Avatar
Turn that boost down if you out of alky. Don't let people confuse your laziness for stupidity.
Old Jul 28, 2005 | 10:56 AM
sleet's Avatar
Just turn the boost way way way down to what you ran before the alcohol.
Old Jul 28, 2005 | 11:00 AM
GOKOU's Avatar
Depending on how the alky was set but should be nada. Alky won't spray at anything below the set point so do yourself a favor and don't go WOT or do it and let u know
Old Jul 28, 2005 | 11:06 AM
Chris@nolimitmotors's Avatar
seems that most tuners are starting the aggressive timing at as low as 14 psi. Its not like you can set the alcohol to only spray at 21 psi and above as far as i know. The alky kits usually start at 12-14 psi of boost.
if your out of alcohol, i'd run maybe 10-12 psi until u get more
Old Jul 28, 2005 | 11:13 AM
3deep's Avatar
I already have a kit and this is just a hypothetical question.If your on a long trip and you run out it sucks.Im leaning towards a piggyback so that im not a slave to the alky.
tscompusa
Dec 7, 2016 03:31 PM
EyeDreamt
Nov 22, 2012 04:04 PM
Gruppe-S
Evo 'For Sale' Suspension / Brakes / Handling
66
Jul 9, 2011 12:33 PM
Chasem
13
May 20, 2010 06:26 PM
