DynoJet correction factor for temperature conditions
Old Jul 30, 2005 | 11:59 AM
Smogrunner's Avatar
Here are two uncorrected dyno sheets of the same car, same exact mods, same fuel. The only difference is the atmospheric conditions and the 300rpm difference form the start of the pull.
Now, in theory, the Dynojet should pretty much equalize these two runs when the correction factor is used. So, anyone want to see the same dynochart with the correction factor turned on?
Old Jul 30, 2005 | 12:04 PM
Soon2BEVO's Avatar
i do!
Old Jul 30, 2005 | 12:10 PM
Precision Dyno's Avatar
I don't think it will equalize the numbers. It may come pretty darn close..
But Don't forget the vehicles EFI system itself will need to compensate for the atmospheric changes too..
Old Jul 30, 2005 | 12:17 PM
Smogrunner's Avatar
Here it is with the runs corrected for atmosphere:
Doesn't really correct enough, does it? PrecisionDyno, I believe you are very right about the Evo's ecu also making corrections to keep things safe. So, all you folks with slightly dissapointing hot summer dyno charts take comfort. Fall is on the way.
Old Jul 30, 2005 | 02:29 PM
gonzo's Avatar
Good read smoggy.
Old Jul 30, 2005 | 02:35 PM
3deep's Avatar
Hey smoggy hows your car coming along,are you back on the road.
Old Jul 30, 2005 | 02:55 PM
Smogrunner's Avatar
Motor is completely assembled. It goes into the car on Monday.
Old Jul 30, 2005 | 03:01 PM
3deep's Avatar
Good luck smogman,cant wait to see some numbers
Old Jul 30, 2005 | 05:07 PM
Erik@MIL.SPEC's Avatar
Smoggiespec is alive once more
Decker@Forged
Jun 29, 2016 08:32 AM
David Buschur
18
Jan 6, 2009 09:19 PM
brodienuchies
Aug 20, 2007 09:54 AM
Fast Frank
15
May 6, 2007 03:08 PM
EFIxMR
29
Nov 14, 2005 11:36 PM
