Pics please of BR500 turbo kit installled
Old Jul 31, 2005 | 04:50 AM
Dyno4mance's Avatar
Like the title says....I am interested more in the pipework
Thanks in advance....
Old Jul 31, 2005 | 06:07 AM
Fourdoor's Avatar
Are you interested in BR500 or Buschur GT30R kit? They are totally different, and the BR500 is no longer available. Here is a thread with some pics of my BR GT35R installation. I think they are identical in looks to the GT30R externally. Dave is also now moving to a different setup for the GT30R and GT35R that will be different than mine.
Keith
<edit>link to pics of my setup https://www.evolutionm.net/forums/sh...ighlight=GT35R </edit>
Old Jul 31, 2005 | 07:50 AM
Dyno4mance's Avatar
Thanks for the response....I really need the BR500 as I have a car in the shop that needs some pipe changes and I wanted to see how David intended it to be or if the installer made some errors...
Any further help will be much appreciated
Old Jul 31, 2005 | 03:07 PM
Noize's Avatar
EvoM Administrator
Up
Old Aug 1, 2005 | 07:22 AM
Noize's Avatar
EvoM Administrator
I guess I can only assume only a handful of these kits were sold...
Nobody want to post pics?
Old Aug 1, 2005 | 07:26 AM
4ringturncoat's Avatar
I have a BR500bb (GT30R), I am putting it back together tonight (changed over to studs for the turbo to mani bolts). What pics do you need an I will get them, ie: turbo on bench, on car, from below, above? Let me know and I will get them for you tonight.
Old Aug 1, 2005 | 08:00 AM
Dyno4mance's Avatar
I really want pics of the whole kit installed including pipework....I am not sure if this is a complete Buschur kit or just the turbo with some cobbled together pipework....If it has been assembled with the latter I will need to order the parts needed from Buschur
I think I need to re-do the whole system...
the car came in with, amonst other things, a 1g blowoff valve venting to atmosphere on a MAF car and I am sure this is not how David intended it to be....
Thanks in advance for any help you can give as I am not too familiar with Buschur components..
Old Aug 1, 2005 | 10:06 AM
I will get them tonight for you. I know unless he is running some sort of device to compensate for VTA there will be some real problems doing that on a maf.
Old Aug 3, 2005 | 08:34 AM
Here are the pics of BR500bb aka:GT3076r
Old Aug 3, 2005 | 09:26 AM
GOKOU's Avatar
but I was wondering if the type S bov is holding the boost you're running. DO you have both springs? Any stalling issues.
Thanks.
Old Aug 3, 2005 | 09:38 AM
She holds great, I ran a 12.01 on the small spring and stock turbo. With the BR500 on I now have the large spring in set at 3 turns and it has held to 30 psi so far. I think the car did drive a little better on the small spring but with the alky I am running 26 for daily use and didn't know if the small spring would hold.
Old Aug 3, 2005 | 09:43 AM
GOKOU's Avatar
Cool. Thanks for the info. I bought a type s knock-off but was afraid it would not hold 25 psi with the spring mod and with both springs in I was afraid of the stalling so I did not put the bov in yet. I hate to drill the 1g flange and find out the type s will cause issues. I went ahead and bought the forge rs bov. I hope this bov will hold the boost and no stalling or else I'm back to square 1 .
Thanks.
Old Aug 3, 2005 | 10:44 AM
If you drill the flange like I did you can swap back and forth from the Type-S to 1g with no problem.
Old Aug 3, 2005 | 10:52 AM
GOKOU's Avatar
I'm guessing you can use rtv to plug the new holes?
