New SFI ISP/ATi spec damper....
Old Aug 1, 2005 | 03:18 PM
ISPracing's Avatar
Not worth the risk of blowing your motor....
Would you drive your car off the edge of a cliff, just to reach the bottom faster?
What I am really try to say is would you risk the life of your motor just to gain a couple of HP? Most people never take the time to research the importance of the OEM crank damper when removing it and replacing it with a “power pulley”. I am writing this article in order to educate and disperse misconceptions that exist about after-market motor sport technology. After experiencing many problems with customer’s cars, due to the installation of a power pulley, I am eager to address the potential dangers of this product.
The whole concept behind the power pulley is that they may add a few HP by slowing down the speed of the accessory drive( all your accessories), but end up reducing the life span of your motor and rob power at certain RPM ranges. Yes, the power pulley will minimize the parasitic losses that rob power from the motor, which most companies claim to increase power by replacing the OEM harmonic damper with a lightweight pulley, but there is a significant amount of problems that can be related to this pulley that can be damaging. The harmonic damper is essential to the longevity of your motor.
It is also key to understand that Mitsubishi forms a team of qualified engineers to design these engines in your car, while these power pulleys are manufactured, sold to you and installed on your car by people who don’t understand the important principle of physics that go into designing these motors.
First I would like to give a brief description of how a crankshaft is designed and an explanation of the principles, which are vital to the correct operation of an engine. If you look at both sides of your crankshaft, on one side you have your flywheel and clutch, and on the other end you have the timing chain/gear drive and a small nose to which the damper bolts directly to. In the middle of the two ends of the crankshaft you have the bearing and main caps that bolt up to the block, which keeps the crank in its proper position. Last you have all your other components, this is your main source of crank twist and vicious harmonics, such as the rings, pistons, rods, and pins. In order to create power your pistons have to travel up and down the cylinder. Every time the cylinder fires, force is transformed through the piston and rod to the crank journal, this causes the rotation of the shaft. The sequences of forces that the crank is subjected to is ordered into tangential torque curves which can be either determined as a constant mean curve or INFINTE number of sine wave torque curves. These curves are known as harmonics, which follow an order that is dependent on the number of vibrations per revolution. The crank torque is made up of many harmonics of varying amplitudes and frequencies, which the name harmonic damper originates from. As the crankshaft revolves at an RPM such that the harmonic sine wave frequency coincides with the natural frequency of the shaft, resonance occurs. The RPM to which this resonance occurs is called a critical speed. As your engine rev’s through its possible RPM range it will pass through multiple critical speeds which can be classified into two categories, major or minor.
Major and minor critical RPM’s are quite opposite, of course, due to the fact that some harmonics cancel each other out or actually help one another in the production of larger vibrations. The important ones are the ones that build harmonics together, which are the major critical RPM’s. So this leaves us with the minor criticals, which cancel out the oscillations of the crank. If the rpm of the motor stays at or near one of the major criticals for an elongated period of time this can cause a fatigue failure to the crank. The major’s are very dangerous, which they must be dampened. Major and minor problems can result from an undampened shaft. If this problem is not resolved this can lead to damaged crankshafts, gearbox replacement, sheered crank pulleys and flywheels from the crankshaft.
With in the motion of a motor something is always off centerline, so it allows the revolution of the crankshaft. This is why the crank will tend to twist as the assembly is forced to revolve. When a cylinder fires, the piston is being forced downward, this is a power stroke. Now imagine this going at a rate of 7,500 rpm’s, this force causes the shaft to twist in one direction, away from its original position, and then when the cylinder stops firing it tries to settle on its original location, its momentum causes it to pass that original position and beyond, this is what is called crank twist. This action is what robs your engine of HP and begins to break parts when there is nothing to dampen or eliminate the twist. The amplitude of the vibration varies along the shaft, placing the worst torsional vibrations, farthest from the load or flywheel.
At the point when these vibrations reach the front section of the motor, crankshaft failure can occur. This can be prevented by mounting some form of vibration damper at the front of the crankshaft that is capable of counteracting that motion. This is where you need your damper. The dampers purpose is to absorb and dissipate as much twist and vibration as possible. With the right damper it will absorb almost all of your twist, but with the wrong damper, such as a power pulley replacement, virtually all of the twist will remain. Keep in mind that your Evo motor is design with a tuned rubber damper straight from the factory.
Now you may be asking yourself, what does this have to do with HP? To answer your question, remember from what I stated earlier, that the crankshaft drive is located at the front of your motor. If the front of the crank is twisting then so is the drive, and if the position is changed then your motor cannot accurately induce, combust and eliminate the fuel, which in the long run with cause a loss of power. To help solve this issue you must have a damper that you can rely on. The stock damper that comes from the factory is a piece of metal with a rubber ring inside that has been melted between another piece of metal. The only problem with this design is keeping the concentricity of the inertia during manufacturing. This has to be solved by machining and balancing the damper after the rubber has been molded, but if the ring slips you lose your timing marks and balance. Needless to say the stock damper will work fine as long as you don’t make any changes to your motor. If you do decide to make changes then your stock damper can no longer be relied on.
In addition to any crankshaft issue, there are all sorts of problems that may arise from the use of a power pulley. Slowing down the accessories assembly below their designed speeds can result to inadequate charging of the battery, dimmed lights, and electronic malfunctions. Also a major issue would be the slowing down of your water pump which can lead to over heating of the engine, nobody needs that. Though it would be possible to implement these corrections either with design or software but I think it is easier to avoid these scenarios in general. We at Infinite Speed and Performance feel that our customers deserve the highest of standards when it comes to development of a product and this is why we put more effort into products that ensure the safety as well as performance of your vehicle than our competitors. As a result we, long with ATI, have developed the harmonic damper for the Mitsubishi EVO VIII.
Pics are here: damper
Old Aug 1, 2005 | 03:28 PM
Precision Dyno's Avatar
Well can't access the link. Can you post the pics here?
Good job guys. How much?
Old Aug 1, 2005 | 03:45 PM
ISPracing's Avatar
We haven't finalized the pricing yet, but we will be organizing a group buy, so check out the group buy section for updates. Thanks!
STM Tuned
31
Feb 9, 2016 06:12 AM
the_cosworth
Lancer Engine Tech
56
Aug 9, 2007 09:16 PM
a1091156
37
Mar 19, 2007 10:28 AM
MattGold
24
Oct 17, 2005 09:54 AM
gldenchld
27
Apr 26, 2005 11:25 AM
