few questions about stroker kit
Old Aug 4, 2005 | 12:44 AM
EvoPanda7's Avatar
sorry i know this must have been brought up 1000 times and i should ahve put it on the search engine... but what would be a good turbo that would go along with the buchar stroker kit? i want a turbo that kiks in at 3500 or so(with tune of course) and can make around 400whp =)... will the 20g be ok? and what kinda cam duration should i get?
Old Aug 4, 2005 | 05:25 AM
GTVEVO's Avatar
I would go with a GT30 Series honestly. It will get you what you want and you can choose (trim) depending on how you want your HP to be delivered.
Old Aug 4, 2005 | 05:31 AM
Big Boost's Avatar
I agree with GTEVO, if you are only looking for 400awhp look at the GT30R line-up. With a stroker, it should spool close to 3500rpm and give you close to 400awhp on pump gas, with a good tune.
I would also recommend getting your head done, as you will want to be able to flow the extra air your engine is moving.
Old Aug 4, 2005 | 05:36 AM
Curt@MrLed's Avatar
Former Vendor
if thats all the horse your going too run, you do not need a stroker kit.. your wasting money.. unless you smoked your motor already..
Old Aug 4, 2005 | 05:52 AM
gsujeff55's Avatar
he might want early spool with 400whp on pump fuel....only way to get that is strokin it.
hur hur, i said strokin it, hur hur
Old Aug 4, 2005 | 07:55 AM
evo8_m3's Avatar
if your only looking for 400whp. I would just run stroker with alky kit and 272's (stock turbo and assuming you already have 02 housing and 10.5 hotside) and should be putting a little over 400whp.
Why go with stroker vs turbo kit ? ... well you'll have better bottom end if you decided to go for a more aggressive setup at later time. On the other hand, you can just go upgrade your pistons \ rods and get a GT35R.
Personally, I'm planning to go with stroker kit with Buschur 20G and stick with my HKS 264's.
Old Aug 4, 2005 | 09:55 AM
EvoPanda7's Avatar
i see... well i dont want the alky kit... and i live in cali =) land of **** gas.... 91 octane ... its hard to get any horse =( if i try and raise my boost i think ill loose hp lol... maybe the stroker kit will help im also planning on getting new radiator / intercooler to keep temps down, good idea? i wana run a gt30 turbo at around 22psi
Old Aug 4, 2005 | 09:56 AM
EvoPanda7's Avatar
thanx everyone
Old Aug 4, 2005 | 10:06 AM
evo_il8's Avatar
I would go with a buschur stroker kit, and an FP3065 Turbo, with 272, 272 cams, and a utec or an aem ems
Old Aug 4, 2005 | 10:10 AM
evoviiiyou's Avatar
I think a fp28 or fp30 series with cams and aem ems..should do it for you.
