HELP...Mis-firing...
Old Aug 6, 2005 | 07:36 AM
MR's Avatar
MR
Hi guys...
A friend of mine has been having misfiring of his spark plugs...
He has a 2.3L block, ported & polished the top, 270 cams, walbro & a paxton external fuel pump, after-market intercooler, fuel reg, bigger fuel rail, aquamist, GT35r .82 & AEM on his evo.
He is boosting at 2bar....
But after a couple of pulls on the road, the mis-firing came in. ..the boost just flutters & the engine stutters....
He put in a HKS twin power & changes his plugs to a set of NGK which is a range colder than stock. Still happen after a couple of runs.
Than he decided to change to NGK racing which is number 9. Regapped it slightly. Same cycle repeats...
Wat could this be?
Thanks...
Old Aug 6, 2005 | 07:45 AM
DCSilvrEvo's Avatar
What are the plugs gapped @? I had the misfire problem and i took the gap down to .20 and problem solved. Im on stock turbo though running like 21pSI.
Old Aug 7, 2005 | 01:57 AM
MR's Avatar
MR
will your gapping cause the spark to be less bright since u gapped it til so low?
i tink he gapped it to 0.3
Old Aug 7, 2005 | 05:39 AM
MalibuJack's Avatar
Because your saying its occurring after a few runs, it could be the coils overheating.. Although I haven't experienced what your describing, you might want to swap on a new set of coils and see if that helps..
Old Aug 8, 2005 | 08:19 AM
MR's Avatar
MR
That is a idea, i will let him know.....thanks MalibuJack...your HKS DLI write-up on your ride is helpful.. ;>
Coil overheats when they are old ixit?
Old Aug 8, 2005 | 08:24 AM
Curt@MrLed's Avatar
Former Vendor
gap should be around, .24-.28..
Old Aug 8, 2005 | 09:20 AM
dome2dome's Avatar
Just check timing light.
Old Aug 9, 2005 | 03:44 AM
MR's Avatar
MR
may i know wat is a timing light?
Old Aug 9, 2005 | 10:46 AM
VTECH8TR's Avatar
Originally Posted by MR
Hi guys...
Wat could this be?
Thanks...
Malibu has a good point. Also have him pickup a set of NGK BPR8ES (colder plug) and some BPR7ES and gapped them down to .25 jsut to see if you have any issues. If you don't then open up the gap little by little.
Old Aug 9, 2005 | 04:55 PM
timzcat's Avatar
It sounds like he is either fouling the plugs or the car is leaning out.
Everytime he puts plugs in it runs fine until he does a couple pulls then the plugs crap out.
What do the plugs look like? Black, Brown, white?
Old Aug 9, 2005 | 07:43 PM
MR's Avatar
MR
Both of us took out the plugs, & it is sorta of blackish brown....
What are the data from AEM EMS that u guys need so that u can advise wat's wrong with it? Let me know & i get him to pass it to me.
Old Aug 10, 2005 | 12:38 AM
2.3EVO8's Avatar
i have the same set up with utec and stock ignition and have the same problem, i just had to turn the boost down to like 22-23 PSI and it runs fine. Im waiting for my AMS ignition to get back.
Old Aug 10, 2005 | 01:48 AM
MR's Avatar
MR
But tot for the GT35r to kick in, u have to boost around 28psi & above?
With your 22-23psi boost, wat r the figures u r hitting? wat rpm than u see your powerband coming in?
I am so worried that i will face the same set of problems too..if not i will have to opt for the 3071r kit instead of the GT35r...
gocchin
Sep 5, 2014 12:15 AM
SinisT3rSRT
Mar 3, 2012 09:10 PM
mxguy1286
Jan 26, 2011 03:53 PM
EVONation
Dec 1, 2007 07:30 AM
whitersevo
11
Feb 14, 2007 05:56 AM
