someone help please
Old Aug 6, 2005 | 08:23 AM
raiceboi697's Avatar
someone help please
so i went to the strip yesterday for the first time and after i figured out the mystery of launching this car. disaster hit. in the higher rpm(6500 to redline) i heard a loud noise like air was being forced into something and i lost boost quicker then a civic is slow. this happened on my second and third pulls down the strip. on the way home i got on it a lil bit and nothing =. the sound never came back. someone help please!!!!
Old Aug 6, 2005 | 09:04 AM
8URVTEC's Avatar
Did you check all your hoses and clamps?
Old Aug 6, 2005 | 09:05 AM
checked last night at the strip gonna check it again with light this mornin
Old Aug 6, 2005 | 02:41 PM
Warrtalon's Avatar
I'm going to guess that you have the stock intake snorkel in place but not fastened down. If you still have the stock intake and that snorkel that draws air from under the front of the hood, make sure BOTH plastic clips are there, otherwise the snorkel sucks up against the hood, makes a loud whooosh sound and takes away all your boost. I'm serious...go check.
Old Aug 6, 2005 | 02:46 PM
2.3EVO8's Avatar
Might have been your BOV
Old Aug 6, 2005 | 03:19 PM
Warrtalon's Avatar
Very doubtful unless his mod list is incomplete...
Old Aug 6, 2005 | 05:51 PM
well checked all the connections and hooked it up according to the evomoto website. everthing is set up like that says. both of those plastic things fell out a broke and im in the process of gettin new ones. if anyone has the greddy profec b spec 2 controller could u give me a heads up on settings cause the ones i found on the boards, (set @ 35%, gain @ 15%, start boost @ 14%, warning @ 22) dosent work. i cant get abpve 10.7 psi now. BTW i have the stock BOV
Old Aug 7, 2005 | 05:18 PM
ok i set it up back to how i had it with the greddy boost solonoid tee to teh factory solonoid and still 11.7 pounds constant.. somebody help please
kaonashi
Aug 5, 2012 05:30 AM
turbodsm420
Feb 8, 2012 11:28 AM
fastassfourdoor
Jul 3, 2007 10:48 PM
morgo333
Oct 19, 2006 01:17 AM
bbbwrx
23
Jan 24, 2005 03:52 PM
