Bleeding the acd?
Old Aug 12, 2005 | 09:26 PM
whiteevo311's Avatar
Bleeding the acd?
Who knows how to do it? Im finally installing my clutch on my 05 and Im worried about bleeding the acd. Any info would be greatly appreciated. thanks in advance.
Old Aug 13, 2005 | 12:20 AM
bumppp
Old Aug 13, 2005 | 08:41 PM
Hyper_Rev's Avatar
I would like to know too. Any help?
Old Aug 14, 2005 | 02:20 AM
EVOVII_SWE's Avatar
It’s not much different from bleeding your brakes. But with a big BUT, you need the Mitsu test computer to force run the ACD pump. And make sure you have enough ACD fluid in the reservoir since the pump is very powerful and you might very easy drain all the fluid if you are not careful when opening the nipple on the transfer case.
Good luck,
Old Aug 26, 2005 | 07:09 PM
Hyper_Rev's Avatar
Good luck,
Thanks for the info
Old Aug 26, 2005 | 07:17 PM
Spec'd's Avatar
So you have to take your 05 Evo Mitsu to the dealer, just to change the clutch ?
Old Aug 27, 2005 | 06:39 AM
Drifto's Avatar
If you don't disconect the line going into the transfer case then why would you have to bleed it? Can't you just push it aside, like you do on a non-ACD transfer case, when removing the clutch?
Old Aug 28, 2005 | 05:19 PM
Anyone know the answer to this question?
Old Dec 20, 2005 | 07:43 AM
EVSEVO8's Avatar
You have to remove the banjo bolt to get to one of the tc bolts. The long one.
tauro91
Jun 29, 2017 02:14 PM
Monochrome
Dec 24, 2015 06:24 AM
TommiM
Feb 9, 2014 12:28 PM
kmartizdatruth
Oct 9, 2009 09:08 PM
Boost3dxEvO
Aug 22, 2009 06:58 PM
