US ACD bleeding with EVOScan
Old Apr 10, 2010 | 02:46 PM
Monochrome's Avatar
Has anyone gotten this to work? V2.7 supports this but it won't connect to my EVO 9 ACD ECU.
Old Apr 10, 2010 | 05:57 PM
inco9nito99's Avatar
There are easier ways to bleed the ACD w/o use of EvoScan or a MUT tool.
Old Apr 10, 2010 | 06:24 PM
lan_evo_mr9's Avatar
Ignition on, gas pedal to the floor for 10 seconds....presto. ACD pump will be activated and adjust fluid levels as necessary.
Old Apr 10, 2010 | 07:27 PM
Monochrome's Avatar
That is not working with my car. The pump is good. The ACD ECU won't activate it for some reason.
Old Apr 30, 2010 | 08:11 AM
fixem2's Avatar
Can you hear the pump activate? How does this "bleed" the unit of air?
Old Apr 30, 2010 | 08:27 AM
rawkus's Avatar
Yes you can hear the pump activate. There is a bleed screen on the bottom of the transfer case. You open this when the pump activates and close when the pump shuts off.
Dan
Old Apr 30, 2010 | 08:30 AM
fixem2's Avatar
^^^Thanks, I tried this yesterday and heard a click and that was it. My process was turn ignition to ON but not started and push the gas to the floor.
Anyone have the ACD Error code list?
Old Apr 30, 2010 | 08:36 AM
rawkus's Avatar
These are from my Evo VII service manual, so I am not 100% sure if they match USDM cars... proceed with caution.
Dan
Attached Thumbnails US ACD bleeding with EVOScan-codes1.png   US ACD bleeding with EVOScan-codes2.png
Old Apr 30, 2010 | 09:12 AM
fixem2's Avatar
Thanks, that is helpful. I am going to use the Pin 1 and 4 short method to try and see the error code. If not then I will have to find an OpenPort 2.0 cable or someone with a MUT III tool.
Old May 1, 2010 | 04:46 AM
Monochrome's Avatar
Mine was doing this as well. It finally started working after taking the car out for a drive. After that, I was able to "throttle bleed" the system.
Old May 1, 2010 | 01:24 PM
Asmodeus6's Avatar
The ACD gas pedal bleed doesn't work all the time. But it does work 90% of the time IME. If you are just bleeding it - you could try a fresh ignition and then shut the car off and see if that makes it work again.
It's a little inconsistent at times, but it should work.
Old Dec 24, 2015 | 12:16 AM
fugiwara's Avatar
No need to get under the car and bleed it?
Old Dec 24, 2015 | 06:24 AM
Raptord's Avatar
Yes, you need one person under the car to open the bleeder while another is pressing the gas pedal.
BoostNY
Apr 4, 2016 06:00 PM
Giuna99
Mar 28, 2016 06:57 PM
tasevo
Mar 12, 2016 06:06 PM
k2evo
Mar 10, 2016 02:46 PM
lancerrally45
Mar 2, 2016 01:08 PM
