What Alky kit better
Old Aug 13, 2005 | 10:41 AM
mikiblueeyes's Avatar
Question What Alky kit better
Question for all those who have alky kits.
Which kit to get ? I was thinking Buschur or AMS?
If you can please state pros and cons for each!!!
Thanks
Old Aug 13, 2005 | 10:51 AM
smokedmustang's Avatar
the AMS (alky control) I think you can put water or meth/alky in that kit, the other only water I THINK. the AMS kit has a bigger pump also. do research, this is just my 2c
Old Aug 13, 2005 | 10:55 AM
I think can put alky/meth in the buschur kit as well.
Old Aug 13, 2005 | 10:57 AM
cool, then check the pump sizes, you want the biggest one!
Old Aug 13, 2005 | 04:47 PM
Monkey's Avatar
why cant you put alcohol in the Cooling Mist system?
Old Aug 13, 2005 | 04:50 PM
4TUN8's Avatar
I'm pretty sure that you can put alchy in the cooling mist systems. I think the problems arise from 100% methanol. I'm not completely sure though. I'm going to fabricate my own alchy kit I think, not so much for running increased boost but a small shot of alchy just as a safety factor and cooling properties. I don't want to make my AFR's too rich, but I do want to cool the charge air, and from what I can tell, you'll benefit more from the 200 bucks to make your own kit then from buying a big front mount and pipes.
I'm going to do my own testing and hopefully get the car up on TT's dyno.
Old Aug 13, 2005 | 04:52 PM
Kronik's Avatar
Coolingmist systems are alky safe.
Old Aug 13, 2005 | 06:42 PM
SlowCar's Avatar
No! the diaphragm is santoprene and the valves are viton. viton swells will swell in the presence of pure methyl alcohol and i think there is also leaking issues. Coolingmist pumps = shurflo pumps, call shurflo for more info.
50/50 mixture is fine
Old Aug 13, 2005 | 06:44 PM
Kronik's Avatar
Well I sure hope you are incorrect -- for the fact they sell it on their website being safe for alky. I'll call shurflo to be sure, but as of yet I have not had any problems with mine.
Old Aug 13, 2005 | 06:45 PM
evo_il8's Avatar
i would go with ams, ive heard good things and seen them
Old Aug 13, 2005 | 06:50 PM
SlowCar's Avatar
ams pumps = shurflo pumps too
Old Aug 13, 2005 | 08:10 PM
NocturnalEVO's Avatar
what about that SMC kit?
Old Aug 13, 2005 | 08:13 PM
SlowCar's Avatar
smc kit = buschur kit = fuel pump =i think you can only run straight methanol w/ additive in them
Old Aug 13, 2005 | 08:17 PM
turboDan's Avatar
SMC kit = Buschurs or Dynolash kit,and I think you can only get the SMC kit from Buschur or Al,not certain,but I "think" that is the only way you can get it,or maybe it is the same price from them as it is from SMC,and more readily available.Also 100% METH is no problem with the SMC/Buschur?Dynoflash kit
Old Aug 13, 2005 | 08:18 PM
SlowCar's Avatar
hmm...just checked buschur, looks like they got a new pump that can run mix
