Bearing Cap Removal
Old Aug 14, 2005 | 12:28 PM
slvrevo's Avatar
Question Bearing Cap Removal
hi all,
started to replace my cams with GSC's 272/264's. following the evomoto instructions... the install has been going pretty good until the point where you remove the bearing caps on the cams. on my exhaust cam all 6 caps are stuborn and don't want to come off. 2kmi on motor.
what's the best way to crack these loose..?
evo moto mentions to put a breaker bar across the head and a crow bar to pry up the cams. is there another way...? i've tried this up to a point. i don't want to crack or deform the casting as it seems like a lot of force to even get it to budge.
tried tapping the caps with a rubber mallet but, no good. any ideas?
tia.
slvrevo
Old Aug 14, 2005 | 01:03 PM
Nad1370's Avatar
Put the cap bolts back on but don't screw it in.
Hold the 2 bolts and rock it back and forth until they break loose. One cap at a time.
Old Aug 14, 2005 | 01:56 PM
slvrevo's Avatar
Nad,
i tried that and it wasn't rocking.
thanks,
slvrevo
Old Aug 14, 2005 | 02:12 PM
Nad1370's Avatar
Stubborn ehh...
Need more leverage. Grab a couple of phillips screwdrivers and put in the bolt holes and try it again. Back and forth, side to side . Don't go in to deep into the threads though.
When I did mine I just put a pry bar under the camshaft and pryed it againts the head where the valve cover sits. Do it slowly though. You don't want those caps flying everywhere when that thing pops out.
Good luck . Let me know how it went.
Old Aug 14, 2005 | 02:44 PM
slvrevo's Avatar
hey Nad,
that did the trick. thank you.
just popped off all 6 caps. they were pretty stubborn though.
slvrevo
Old Aug 14, 2005 | 02:48 PM
Nad1370's Avatar
Glad it worked .
Now put those bad boys in and finish that case of so you can enjoy your new found powa !!!
GSRSTIKILR
May 10, 2017 11:28 PM
fireroasted
20
Mar 27, 2017 08:17 AM
tvor
Aug 20, 2015 02:10 PM
slvrevo84
Jun 7, 2015 03:52 AM
omniprobe
Apr 14, 2009 11:46 AM
