White Rabbit update
Old Aug 16, 2005 | 04:28 PM
  #31
Erik@MIL.SPEC's Avatar
I thought the WR used the same shaft but different compressor wheel. I could be wrong though. I do remember reading that an English guy ordered a WR and had it converted to a BB section.
Old Aug 16, 2005 | 04:37 PM
  #32
dryad001's Avatar
BAM!!!!!!! I know the pic is huge... But it's the WR in all its glory Gosh darn pic is sideways
Old Aug 16, 2005 | 05:22 PM
  #33
954DRGSR's Avatar
Appreciate you posting this Al. Would it be possible to put up the dyno sheets?
Old Aug 16, 2005 | 06:03 PM
  #34
DynoFlash's Avatar
Originally Posted by wikdwhiterabbit
I'd love to see a WR with an Essex BB center! Don't know if it's possible though considering the WR uses a different shaft. Maybe we could get FP to make a BB WR.....a rabbit on rollerskates as it were
I am told I will be testing on of those later this week
Old Aug 16, 2005 | 06:04 PM
  #35
DynoFlash's Avatar
I dont have them - the owner smiley and david buschur may be able to if they read this
Old Aug 16, 2005 | 06:13 PM
  #36
LordEvoIX's Avatar
So essentially, the WR is an upgrade of the compressor wheel which is of the same size as the stocker but of different design? Do you know what material is the WR wheel made of?
Old Aug 16, 2005 | 07:27 PM
  #37
wingless's Avatar
ti turbine wheel, aluminum compressor wheel.
your looking at WR's with an evo 9?
Old Aug 16, 2005 | 07:28 PM
  #38
It's a five blade design. There's more "room" near the shaft, so it can flow more air at higher rpms (after 4500 to 5000 or so).
Old Aug 17, 2005 | 05:53 AM
  #39
wikdwhiterabbit's Avatar
FP said in another thread that the shaft was different...smaller diameter I believe.
Old Aug 22, 2005 | 03:07 PM
  #40
evo400's Avatar
Registered User
we tested the white rabbit and found the same as everyone else did . a garrett bb core will just add to the misery of the units lack of performance . what you guy need is the new mag turbo from the evo 9 . we just ran get this
exhaust
air filter
fuel pump
and a ecutek reflash
@ 1.4 bar
296 hp atw's on a dyno dynamics . with plenty more to come
evoultion is upon us once again .!!!!
Old Aug 22, 2005 | 04:44 PM
  #41
DynoFlash's Avatar
Actually the guy with the ball bearing WR did quite well this weekend with a 11.6 on a reflashed ecu and full weight and lots of stero a/v equipment
Old Aug 22, 2005 | 05:23 PM
  #42
Zeus's Avatar
I'm in the process of a write up to be posted later tonight as to what I've experienced the "problem" to be that people are having with the WR turbo.
Old Aug 22, 2005 | 05:46 PM
  #43
trinydex's Avatar
i wanna hear this ^^^ real bad
Old Aug 22, 2005 | 07:54 PM
  #44
U2SLO's Avatar
WR turbo
I am very happy with the way my car was performing on sunday at the track.I was granny launching my car 2.2 60 ft' and was pulling 117.2 mph 12.4 times.I was the white RS 05 talking with all the evo guy's in the line.It was a really great day but it went by so fast.I was eliminated in the third round caused I bog stalled at the line.I was blowing past STI's mid track I loved it.Go WR!!!
Old Aug 22, 2005 | 09:13 PM
  #45
dryad001's Avatar
I'd like to see this also. I haven't had one problem with my WR. Now that I have a wideband hooked up in my car 24/7 I can log all the time and go back and fine tune the car. Here is a small bit of a log that was done today. My AFR's are still very rich. I wish I could find a log all the way through redline, maybe ill log one up tomorrow for all of you.
RPM__Boost_________Knock_AFR_____Timing
5602,+12.0,1650,100, 50, 00, 10.7, 71.8, +9.9,-24.2,ECU. ,1152
5747,+18.7,1683,100, 60, 00, 10.7, 72.1,+10.4,-24.8,ECU. ,1179
5858,+22.4,1655,100, 70, 00, 10.6, 70.9,+11.7,-25.4,ECU. ,1329
6006,+22.8,1748,100, 70, 00, 10.8, 70.4,+13.8,-25.9,ECU. ,1308
6218,+22.4,1760,100, 70, 00, 10.6, 74.0,+15.2,-26.3,ECU. ,1336
6349,+22.2,1785,100, 70, 00, 10.7, 77.8,+16.3,-26.7,ECU. ,1256
6459,+22.0,1805,100, 70, 00, 10.8, 75.6,+17.3,-27.5,ECU. ,1453
6653,+21.8,1792,100, 80, 00, 10.7, 75.3,+18.8,-28.1,ECU. ,1237
6747,+21.6,1838,100, 80, 00, 10.9, 75.7,+20.4,-28.5,ECU. ,1358
