White Rabbit update
Old Aug 15, 2005 | 07:21 PM
DynoFlash's Avatar
White Rabbit update
Had a chance to tune a WR turbo on member Smiley's car on the Buschur Mustang dyno this sat - the turbo hit 30 psi and fell to 24 psi - (more than stock) - it made 330 whp on the Buschur dyno with Buschur Stage 4 and my custom flash (100 octane tune). To compare, cars with similar mods and stock turbo are pulling about 290 - 300 on that dyno with 94 octane. The dyno sheet looked good - it pulled much harder after 6500 than a stock turbo. (Sorry I did not keep a print out).
Smiley's car ran into the 11's at the shootout. Decent results with his mods and the reflash. I was impressed with the WR performance. Its not a dramataic improvement over stock but its a decent pick up.
Interesting note - compared a dyno sheet of the BR 20G with Stage 4 plus - it spools up sooner and holds power longer - but that is with AEM and more mods. BR 20 G went 11.6 on the track sunday. Time will tell how the 20G fares with the reflash.
Old Aug 15, 2005 | 07:24 PM
gsujeff55's Avatar
yeah, but the guy only ran 114mph right? Acceptional driver....but the trap is low isn't it?
Old Aug 15, 2005 | 07:32 PM
spooledevo's Avatar
I think alot of people were down on there traps speed on sunday!!!
Old Aug 15, 2005 | 07:37 PM
dryad001's Avatar
Here we go again. You only got 330whp on 100oct? Not too sure how the Buschur stages work but that seems kinda low. I know it's a MD, but all depends on what the settings were on the dyno. My weight is set at 3500 and hp @ 50 is 13.5 (i think)\, have to find my last dyno sheet)
Old Aug 15, 2005 | 07:46 PM
TwStDeVo's Avatar
hopefully we can see a stage 4 flashed car with the 20g soon!! Man elevation sucks!! i purchased a 35r and now gonna return it for the 20g depending on the results due to the fact that spool up on the 35r seemed like it would be horrible where i live (never installed it, just took advice from couple of board members).
Old Aug 15, 2005 | 07:55 PM
matt55's Avatar
Dave's RS (20G) "only" made 330-340 on his dyno when they frist got it installed . soo where are we going?
Old Aug 15, 2005 | 08:00 PM
GOKOU's Avatar
I agree. A final # means nothing without an initial number especially when numbers vary from dyno to dyno I like to be tune on the dyno so I can see the difference rather then using the feel/butt dyno method.
Old Aug 15, 2005 | 08:11 PM
gsujeff55's Avatar
well, it WAS on the same dyno
Old Aug 15, 2005 | 08:15 PM
GOKOU's Avatar
Not sure what you mean but I believe BR changed the setting since their black car was dyno since the number made no sense
Old Aug 15, 2005 | 08:19 PM
gsujeff55's Avatar
nope, same setting it came out of the box on. Either way, no sense in focusing on dyno numbers. Need a before WR and after WR dyno to mean anything.
Old Aug 15, 2005 | 09:23 PM
DynoFlash's Avatar
This is why I gave you guys the track time and dyno number from same weekend so you can have an idea of what the number means
Old Aug 15, 2005 | 10:45 PM
Zeus's Avatar
...the wastegate is leaking boost.
Old Aug 15, 2005 | 10:46 PM
Zeus's Avatar
PS, fix that and put a Hallman on there if there isn't one already, and you should hold much more boost.
Old Aug 16, 2005 | 03:02 AM
trinydex's Avatar
oooh intriguing...
Old Aug 16, 2005 | 03:10 AM
LostSoul Evo's Avatar
but dave is running an AEM EMS wit more mods when he made that power. (as stated by al in the original post). this WR that al just ran is running just a bushcur stage 4 and a flash. so i guess at this point the WR is looking the best. thats until al can get a 20g with a buschur stage 4 and a flash and compare the the numbers and dyno sheets.
